10,500lb Winch for $399.99! 8,500lb Winch for $299.99! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old August 8th, 2009, 10:29 AM   #1
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Default 10,500lb Winch for $399.99! 8,500lb Winch for $299.99!
For the budget-minded wheeler:
Heavy Duty 10,500lb Winch
Durable. Tough. Affordable. The Heavy Duty 10,500lb Winch from Rugged Ridge is everything you could want in a winch. It is driven by a durable 6.6 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 218:1 gear ratio delivers power and reliability on each and every pull. The Heavy Duty 10,500lb Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge steel cable style Winches include off road light mount roller fairleads allowing for the easy mount of two off road lights! Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to “tilt” the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
Heavy Duty 10,500lb Winch Features/Specifications
  • Durable 6.6 HP Series Wound motor for long life and extra pulling power
  • Tough 3-Stage Planetary Gear box with a 218:1 gear ratio
  • Includes 94’ of 23/64" diameter wire rope and latched hook
  • Automatic load-holding brake system (in the drum brake system)
  • Exclusive light mount roller fairlead included- allows for easy no-drill mounting of up to 2 off road lights!
  • Tough stainless hardware on the body of the winch to eliminate rust
  • Each winch includes a durable 12’ all-weather cable remote.
10,500lb winch for $399.99 - http://jeeperz-creeperz.com/product_...ucts_id=107374
Also available in 8,500lb for $299.99 - http://jeeperz-creeperz.com/product_...ucts_id=107373
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Last edited by Jeeperz Creeperz; September 9th, 2009 at 03:00 PM. Reason: Layout Changes, additional info
Old August 9th, 2009, 09:43 PM   #2
Clay
Fishin' rig
Clay's Avatar
I need one
Clay is offline   Reply With Quote
Old August 11th, 2009, 03:42 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Originally Posted by Clay View Post
I need one
We have one!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old September 1st, 2009, 04:16 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Bump!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old September 1st, 2009, 04:20 PM   #5
All5ofus
All5ofus's Avatar
Do you have the 8500lb RR winch? If so, what's your price on it.
It was funny, I was just looking at these on another site when your post poped up.
All5ofus is offline   Reply With Quote
Old September 2nd, 2009, 09:58 AM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Price on the 8500 is $299.99. I don't stock that winch because it's really borderline for most of the vehicles that would require one and for a little more you get a more heavy-duty winch. I can order one no problem, if you're interested.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old September 2nd, 2009, 10:10 AM   #7
95geo
newbie
95geo's Avatar
Is this by chance the replacement company that bought out the t-max brand last fall?
Old September 2nd, 2009, 10:33 AM   #8
Jeeperz Creeperz
GL 4x4 Vendors
No, T-Max was bought by Westin.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old September 2nd, 2009, 11:06 AM   #9
Muttly
Muttly's Avatar
line speed?
Muttly is offline   Reply With Quote
Old September 2nd, 2009, 12:17 PM   #10
95geo
newbie
95geo's Avatar
Do you have any idea what street name they will have?
Old September 2nd, 2009, 12:20 PM   #11
liv2mx
i like jungle gym's.
liv2mx's Avatar
they are still tmax but the new ones have westin stamped on them also.i just went through a major warranty issue with them. had to speak to the vp of westin to get it fixed....any old tmaxx has NO WARRANTY since westin bought them.
Old September 2nd, 2009, 12:20 PM   #12
jeepnxj96
jeepnxj96's Avatar
Originally Posted by Muttly View Post
line speed?
at 218:1 slower than the smittybuilt and faster than the milemarker 8000lb winches.
Old September 2nd, 2009, 06:35 PM   #13
Jeeperz Creeperz
GL 4x4 Vendors
line speed?
Smittybilt has the same ratio on their XRC10, so I'm not sure how you're doing your calculations and I can't find specs for the Smittybilt anywhere.
Specs for the winch can be seen here: http://www.jeeperz-creeperz.com/heav...-p-107374.html
And it depends which Mile Marker winch you're comparing it to. It's slower than the V10 winch, but that has a 130:1 ratio so the motor has to work harder. It's slightly slower than the VSX9.5 (212:1) until you get to 6000 pounds, then it's faster. And it's faster than the VMX8 winch all around.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old September 9th, 2009, 03:02 PM   #14
Jeeperz Creeperz
GL 4x4 Vendors
Added the 8,500 price and link!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old October 1st, 2009, 05:02 PM   #15
Jeeperz Creeperz
GL 4x4 Vendors
October Bump!
Thanks for the orders!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old March 24th, 2010, 11:04 AM   #16
Jeeperz Creeperz
GL 4x4 Vendors
Bump!
Now stocking all 4 winches! Pick one up and save on shipping!
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Tags
winch
Thread Tools
Page generated in 0.31858 seconds with 71 queries
