Big Red Tracker (CAGE DONE!) wohoo - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2010, 10:54 PM   #121
hydro joe
liquid joe
hydro joe's Avatar
Jim did you do all the work if you did dud the cage would have been great. I have been bashed about my square tube buggy alot. And i think people mean well but it gets lost, so remember they are trying to be helpful. The start looks great post more pic when you can.
hydro joe is offline   Reply With Quote
Old March 30th, 2010, 09:09 AM   #122
95geo
newbie
95geo's Avatar
Starting final prep, paint and assembly. 4 weeks and counting.
Old April 1st, 2010, 08:06 PM   #123
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
And the countdown begins......30 days.
The last time the frame was in this position it was NOT good! Took the opportunity to sand down/wire wheel/scrape the entire frame top to bottom and 'fix' a few welds that were previously unreachable due to the body being in place on the first time around build. Small pile of parts ready to paint. Frame will get wiped down and then I'm going to do the Duplicolor/Rustoleum Bed Liner coating. Dries hard as a rock and WON'T pick up road dirt like rubberized undercoating does. Got a few more on the welding bench to finish up tomorrow and then hit them with paint. Plan right now to assemble engine/trans to frame, and get the shockmounts in place before the weekend. Potentiall set up the R&P if I really get ambitious. Plans still on track to do the body lift off/drop on next Saturday if anyone would like to lend a hand.
j-kb8ymf
ID:	60395   Click image for larger version
ID:	60396   Click image for larger version
ID:	60397   Click image for larger version
ID:	60398   Click image for larger version
kb8ymf is offline   Reply With Quote
Old April 13th, 2010, 06:25 AM   #124
kb8ymf
kb8ymf's Avatar
More updates:
Got the frame coated with Dupli-Color bedliner. Do NOT even try using the new Rustoleum product that is out there. It's watery and doesn't go on like Dupli-Color does. Autozone used to carry the stuff but only carries Rustoleum products now. I had to go to NAPA to get the stuff. It's well worth it. Beside that, it's with a few pennies of being the same price.
Axles set up, assembled, and installed. Shock brackets back on. Engine back in place, measuring for driveshafts and rolling chassis shoved outside for a few days. And in case some of you were wondering.....this is what a 600ft/lb torque wrench looks like! King Pins came off like it was childs play. Go look in Tech section to see how's it's done.
Donor vehicle on the hoist and starting to remove parts and pieces so that body can be swapped.
jim-kb8ymf
ID:	60932   Click image for larger version
ID:	60933   Click image for larger version
ID:	60934   Click image for larger version
ID:	60935   Click image for larger version
ID:	60937   Click image for larger version
ID:	60938   Click image for larger version
Old April 13th, 2010, 06:30 AM   #125
kb8ymf
kb8ymf's Avatar
Parts coming off.
Old April 13th, 2010, 07:26 AM   #126
bearlys2005
bearlys2005's Avatar
Looks great Jim... How many cans of Dupi-Color did you go through?
bearlys2005 is offline   Reply With Quote
Old April 13th, 2010, 08:21 AM   #127
benny87
Young Gun..!
benny87's Avatar
Looks Great!
benny87 is offline   Reply With Quote
Old May 4th, 2010, 09:44 AM   #128
95geo
newbie
95geo's Avatar
Latest.....
ID:	62124   Click image for larger version
ID:	62125   Click image for larger version
Old May 4th, 2010, 06:18 PM   #129
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Holy $hit that's tight! I hope that's shown with some simulated wear in the suspension joints (way undersized bolts with the axle pulled as far back as possible?).
Old May 4th, 2010, 06:42 PM   #130
95geo
newbie
95geo's Avatar
It's a little deceiving, you can fit your hand between them. The tank was a little pushed forward in that picture but it's definately tight though, no arguing that.
Old May 4th, 2010, 09:28 PM   #131
4Bangler
Jackstand Wheeler
4Bangler's Avatar
You must have tiny little micronesian kid hands...maybe you have a future sewing soccer balls.
Photos can be deceiving (your header pics looked wicked close from one angle) I just hope you're not cutting things too close just to get an extra 1/4 gallon in the tank...course that's like an extra 30 miles of fuel range with Tracker drivetrain.
Old May 4th, 2010, 10:28 PM   #132
95geo
newbie
95geo's Avatar
I'm just helping the old man with some crappy welding. The closest spot is to the truss and it's about an inch away, worst case. If you look at where the diff cover is in relation to the bottom edge of the tank you can get an idea of where everything falls. The vertical plates on the diff cover are below the bottom edge of the tank. (first pic in the series) Theres over an inch of clearance to any part of the diff cover.
If you think the diff cover is close, you should see how close the exhaust will be!
Old May 10th, 2010, 11:25 AM   #133
kb8ymf
kb8ymf's Avatar
T minus negative 10 days and counting. So May 1st was a bit optimistic! It is getting close though.
........Brake brackets and fuel cell on the fab list. Due to a brain fart I added 2 inches to the fuel cell which I promptly had to cut off. Luckily it was easy to chop the front end which was square. Still rather tight but only near full compressed.
Brake brackets working out real well except I may have overkilled them a bit. Next version will be a bit lighter and more managable as a bolt on/weld on kit.
ID:	62463   Click image for larger version
ID:	62464   Click image for larger version
ID:	62465   Click image for larger version
ID:	62466   Click image for larger version
Old May 10th, 2010, 11:28 AM   #134
kb8ymf
kb8ymf's Avatar
And the rear brake brackets......
Front not quite ready for prime time.
Next major task is exhaust and 'Y' pipe.
j
ID:	62469   Click image for larger version
ID:	62470   Click image for larger version
Old May 10th, 2010, 12:20 PM   #135
MidMichxj
Wrenchin for a livin
MidMichxj's Avatar
Nice work guys!
MidMichxj is offline   Reply With Quote
Old May 10th, 2010, 01:50 PM   #136
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Very nice work on the tank!
Old May 10th, 2010, 11:18 PM   #137
twelve
twelve's Avatar
Hey man, that thing needs a full cage. All joking aside your rig looks great have fun with it.
twelve is offline   Reply With Quote
Old May 11th, 2010, 12:13 AM   #138
Offroadian
seasoned
Nice work Jim.
Offroadian is offline   Reply With Quote
Old May 16th, 2010, 09:36 PM   #139
kb8ymf
kb8ymf's Avatar
Home stretch......
Brakes done, 35 spline outers axles together, Big arse rotors (13.25") and Wilwood twin piston calipers just clear 17" rims by 1/4". Hubs redrilled to 5 X 5 1/2". I sure as hell better be able to stop on a dime. Geoboy is working the exhaust out as he's become a master @ TIG'ing paper thin stainless. 'FIXED' driveshafts will be here Thursday. Baring any last minute oh, shits, it should be mobile before the weekend......only 22 days late, but still 22 days before I leave for Traverse City and the UFWDA AGM.
j-kb8ymf
ID:	62816   Click image for larger version
ID:	62817   Click image for larger version
ID:	62818   Click image for larger version
Old May 17th, 2010, 07:49 AM   #140
benny87
Young Gun..!
benny87's Avatar
Looks good..
Page generated in 0.39565 seconds with 84 queries
