Advanced Excel Users - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2009, 08:41 AM   #1
Coynster
ecoyne
Default Advanced Excel Users
I have one workbook...
Each tab is dated for the date of the week, ie todays tab is 8, tomorrows 9, etc...
I'd like to create one macro in this worksheet that will analyze some
data and do some sorting for me...
What I'd like to know is how I can program my macro to prompt me
for the Tab to analyze, so I only have one macro to analyze my data...
So, upon activating the macro, the macro would prompt which tab to analyze, and then conduct its sorting, which i have the ability to code myself...
Make sense? Any questions?
Appreciate any help!
Thanks!
Coynster is offline   Reply With Quote
Old August 7th, 2009, 10:08 AM   #2
JeepInABox
In too deep
JeepInABox's Avatar
open tab run macro, open next tab rum macro
or select multiple tabs and run macro
Old August 7th, 2009, 10:12 AM   #3
Coynster
ecoyne
I'd like to set it up with a button macro without having a button on every sheet, hence why I'm asking for help with be setup listed above...
Old August 7th, 2009, 10:42 AM   #4
techman
sName = Application.InputBox(Prompt:="Enter new worksheet name")
Use sName in macro to reference the worksheet name/cells
techman is offline   Reply With Quote
Old August 7th, 2009, 10:49 AM   #5
Coynster
ecoyne
There you go, thank you! Could you quickly write the correct syntax using above to copy cells a1:c1?
So I'd start my macro, it'd prompt me to enter worksheet name, which for todays example I'd enter 7, and then what's the syntax for using the sname command?
Appreciate your help!
Old August 7th, 2009, 11:40 AM   #6
techman
Sheets(sName).Select
Will select the tab/worksheet then just do whatever you need to do, select, delete, format, sum, etc.
Old August 7th, 2009, 11:46 AM   #7
RyeBread
Catch the wave
RyeBread's Avatar
o.O I usually just hit alt+f8 load the macro and run it. sometimes finding an elegant solution is more trouble than it's worth :p
Old August 7th, 2009, 12:06 PM   #8
Coynster
ecoyne
Hmm, hot key may work even better...
Thank you both.. I'm not going for elegance as much as I am simplicity and function!
Old August 7th, 2009, 12:13 PM   #9
JeepInABox
In too deep
JeepInABox's Avatar
I always go for the hot key "shift q" since it one hand and quick to find.
Page generated in 0.23975 seconds with 49 queries
