1997 Chevy s-10 zr2 lift options. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2009, 09:17 PM   #1
steveo
In the band!
Default 1997 Chevy s-10 zr2 lift options.
In a couple of weeks I am going to be helping my cousin lift his zr2 S-10. He wants to keep it simple, 33's, a little lift and a body level. what would be the best way to accomplish this? thanks.
Old August 6th, 2009, 09:39 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
whats his budget? tell him to look into the superlift kit http://www.4wheelparts.com/Lift-Kits...7&t_pn=SUPK328
i've heard a few people who have this kit say they like it very much.
Old August 8th, 2009, 08:01 PM   #3
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
The only real lift kits that I know of are either some kind of 6" suspension lift, or a 2-3" body lift. You can crank torsion bars for a couple inches if your into that and do shackles in the rear.
His budget is the big question.
Grunto is offline   Reply With Quote
Old August 8th, 2009, 08:07 PM   #4
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
I fit 33's with a body lift. Crank the t-bars a little bit if it still rubs , but I wouldnt crank them any more than 1.5"-2". The lift options are either the 5 inch BDS , the 6 inch Superlift or a 2 inch body lift. The 3 inch body lift from the old style s series can be modified to fit the zr2.
33x10.5's are alot easier to fit than 33x12.5's.
What rims is he going to be running ?
JohnL is offline   Reply With Quote
Old August 9th, 2009, 07:25 AM   #5
steveo
In the band!
Thanks guys. I am going to suggest to him a 2" body lift, 2" on the torsion bars and I will make him some 1.5" shackles. I am pretty sure he will be running stock rims. I have suggested 33x10.5, I have a set for my zj and will be runnung them soon. His main concern is fitting the 33's and making the truck level. He is still concerned with form over function.
Old August 11th, 2009, 11:43 AM   #6
ZR2 kid
ZR2 kid's Avatar
I have a 2" body lift on my zr2 and i was able to fit 32x11.50 with a little trimming on the front bumper. i had to crank the torsion bars a little but not even have way and i went with a 0 offset rim with i believe close to stock backspacing but dont hold to that lol
ZR2 kid is offline   Reply With Quote
Old August 13th, 2009, 10:02 PM   #7
Grunto
Grunto's Avatar
Stock backspacing is 6".
I had just a 2" body lift with 30's, and a set of Cragars with 4" of backspacing and it rubbed at full lock. That was not a ZR2 though
Old August 13th, 2009, 11:58 PM   #8
beedle4
beedle4's Avatar
Yeah
2" BDS or PA body lift
3" PA body lift for a 94 ZR2 (all works the same but the rear bumper brackets, they will need to be fabbed up)
2" superlift (even with this kit 1.5" over Z height is the only "SAFE" crank. So skip it and crank 1.5" and add 1.5" or 2" shackles)
5" BDS suspension
6" superlift suspension
It all depends on what tire he goes with as the actual size differs alot. Most 33's range from 32"-34"
Also depends on how he will wheel it.
I have 5" BDS, 1" body lift with almost 33's and I rub on hard compression and full lock turns...
Old August 14th, 2009, 12:11 AM   #9
beedle4
beedle4's Avatar
Or better yet if he has the money/time to go SFA, Diversfield Creations in Brightion is now offering an awsome 4-link "kit" that is set up to use a TJ turd 30, dana 44, or any axle with those mounts.
http://www.diversifiedcreations.com/...uctsSASKit.asp
pics...
http://www.diversifiedcreations.com/...ory.asp?id=105
Also if he decides to go with a suspension lift Mike is having his 5th anniversary car and truck show next SAT. And he has told us that the BDS kits will be for sale at an all time lowest price of the year that day...
http://www.diversifiedcreations.com/dcDefault.asp
Also if he is not a member of ZR2usa.com please tell him to join. He will find alot more info there.
Page generated in 0.26057 seconds with 50 queries
