How much lift w/o Rad arms/Pitman arm/brake lines - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2009, 11:25 AM   #1
boggi
wen in doubt throttle out
boggi's Avatar
Send a message via MSN to boggi
Default How much lift w/o Rad arms/Pitman arm/brake lines
do you think i could throw a 3" lift coils and 3"rear blocks on a 79 bronco without needing brake lines or pitman/rad arms?
i will be getting a set of custom extended radius arms but that will be over time, and same deal with the pitman arm(only not custom made lol) and extended brake hoses will probably be first on the list, theyre cheap arent they?
boggi is offline   Reply With Quote
Page generated in 0.18200 seconds with 26 queries
