durango lift question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 6th, 2009, 10:32 AM   #1
prozak1986
prozak1986's Avatar
Default durango lift question
my friends got a 98 durango 4x4 with a 5.2 ( i think ) , i was under it yesterday because i noticed hes got tortions , can i tighten those a little and lift his truck ( tighten them by the bolt ware they key is ) , hes not looking for anything huge maybe 1-2 inches , also hes looking for around 2inches in the back , whats the best way to do that ? .... any help is a step in the right direction
prozak1986 is offline   Reply With Quote
Old August 6th, 2009, 10:36 AM   #2
greygoose
I'm the dude
greygoose's Avatar
Yes, you can crank the torsion bars, but after you might want to get an alignment. As far as the rear goes, you could get shackles or AALs. (AAL= Add A Leaf)
Old August 6th, 2009, 10:52 AM   #3
prozak1986
prozak1986's Avatar
thanks man , ive never worked on a dodge so i figured id ask before i mess his truck up . , . i was thinking about going to a junk yard with him and pulling the leaves off another durango and adding 1 or 2 leaves to his current setup , think that would work ?
Old August 6th, 2009, 11:38 AM   #4
prozak1986
prozak1986's Avatar
i also got another question about the same durango , hes got a deal on a set of 265/75/15s , will those fit his truck ? hes not lifted yet but will be in the future
Old August 6th, 2009, 03:23 PM   #5
greygoose
I'm the dude
greygoose's Avatar
They should fit. They are about the same as a 31/10.5/15
Old August 6th, 2009, 03:24 PM   #6
greygoose
I'm the dude
greygoose's Avatar
It should work, but the packs are under pressure so be careful when pulling them apart. When I have a leaf added, I just take it to a spring shop. They are fast and usually don't charge too much.
Old August 6th, 2009, 08:08 PM   #7
osnapchuckie
learn after breaking...
osnapchuckie's Avatar
An easier and cheaper way to lift the ass end of that durango would be a lift block for the rear axle its cheaper than an add a leaf. Alot cheaper and alot easier to install. blocks just slide under the axle and u get larger U bolts and u can lift it from 1/2 inch up to 3 inches.
and also it wont affect the ride any. Hope it helps.
osnapchuckie is offline   Reply With Quote
Old August 6th, 2009, 09:23 PM   #8
prozak1986
prozak1986's Avatar
durangos leaf springs are under the axel so if i added a block it would lower it not raise it
Old August 6th, 2009, 09:24 PM   #9
prozak1986
prozak1986's Avatar
he did get those tires thow they measure around 29.5 inches , looks real good , thanks man
Page generated in 0.26178 seconds with 50 queries
