4.3 Wont run - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2009, 03:46 PM   #1
littlegilbert06
littlegilbert06's Avatar
Default 4.3 Wont run
05 Silverado with a 4.3 it starts up and shuts off right away. Checked all the fuses and fuel pressure they were good. Truck ran great parked it and now is doing this? It is also not reading any codes. Any ideas what it may be?
Thanks Camron
littlegilbert06 is offline   Reply With Quote
Old August 5th, 2009, 03:48 PM   #2
axxdet
axxdet's Avatar
Send a message via Yahoo to axxdet
does it rev up at all ... what does it do while it "runs"
axxdet is offline   Reply With Quote
Old August 5th, 2009, 04:05 PM   #3
littlegilbert06
it starts then just shuts off right away even if you play with the throttle
Old August 5th, 2009, 04:11 PM   #4
axxdet
axxdet's Avatar
wow, !!?? trying cleaning the MAF, and the air filter,
Old August 5th, 2009, 04:54 PM   #5
littlegilbert06
air filter is clean maf looked clean but may be dirty still hard to say .... ill clean it and see what happens
Old August 6th, 2009, 12:37 AM   #6
Disturban
Disturban's Avatar
MAP Sensor!
Old August 6th, 2009, 12:59 AM   #7
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
Does it start every time still and then shut off. Or does it mostly just keep cranking for a long ass time?
Is your fuel pump running? Should be able to hear it.
Grunto is offline   Reply With Quote
Old August 6th, 2009, 07:42 AM   #8
jbsjunk
Little Member
jbsjunk's Avatar
This is a long shot, but I've seen the VATS do that a couple times. The anti theft system. It gives a 2 second run and if the right chip or key is in it, it will be fine. If not, it kills the engine.
Old August 6th, 2009, 08:04 AM   #9
greygoose
I'm the dude
greygoose's Avatar
I was thinking the exact same thing. Sounds like a security issue.
Have you gotten a new key lately?
Old August 6th, 2009, 03:28 PM   #10
littlegilbert06
i dont even think it has securtiy lol its just a work truck but anyway it is the factory key.
we checked the fuel pressure it was good it will start run for like 2-3 seconds then just shut off doesnt sputter or anything
Old August 6th, 2009, 03:36 PM   #11
Bishop
Bishop's Avatar
most of them have some sort of a securtiy on them weither you know it or not.
if you have 2 keys try the other one.
Old August 6th, 2009, 09:15 PM   #12
jbsjunk
Little Member
jbsjunk's Avatar
Defiantly sounds like a security issue. ECM kills the fuel pump, and possibly the ignition on something that new.
What does the fuel pressure gauge say when it quits?
How long was it parked, and was the battery dead?
Old August 6th, 2009, 09:52 PM   #13
littlegilbert06
drove it parked it and next day it did this i wasnt there when they checked the fuel pressure. Any way to reset the security?
Old August 6th, 2009, 10:25 PM   #14
jbsjunk
Little Member
jbsjunk's Avatar
Might come down to calling the dealer unless someone has more insight to this. A security issue makes the most sense so far. I have no idea how to reset this.
Old August 8th, 2009, 07:58 PM   #15
Grunto
Grunto's Avatar
Check in or around glovebox for a button for the security deal.
Old August 11th, 2009, 01:38 PM   #16
littlegilbert06
cant figure it out mine as well scrap it
Old August 11th, 2009, 04:50 PM   #17
Disturban
Disturban's Avatar
Check the fuel pressure! My wifes bravada would start and was running real bad, then it would start and shut off, now it wont even start. I am getting 40PSI but spec is 60 to 66psi. I don't know what spec is on your truck but I would assume it's the same...oh and guess what people? I can hear the pump running when I turn the key on...that don't tell you shit just because you hear it running does not mean it's good. Now if ya don't hear it running I would tend to believe it's bad.
PS: If ya want to scrap it I will take it off your hands. Also go to autozone and they have a nice fuel pressure test kit that has a book with pressure specs for every car made this is their loan a tool program and it is free to use, you should have a schrader valve right behind the TBI unit just follow the fuel line you will see it.
Old August 16th, 2009, 08:55 PM   #18
littlegilbert06
Well you all fail. Chip munks had a few wires for dinner hooked all back up and it runs great. Thanks for all the help.
Old August 16th, 2009, 10:59 PM   #19
Disturban
Disturban's Avatar
Well how in the HELL can we diagnose a Rodent problem over the internet
What wires did they chew through...the answer could help trouble shooting future problems of 4.3 liters that are infested with critters
Old August 18th, 2009, 08:09 AM   #20
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
they were camping out under the under hood fuse block chewed the fuel guage sending wire and fuel pump supply under ignition on. it would get fuel while cranking but not when the key was released to the on position
Page generated in 0.33572 seconds with 83 queries
