No oil pressure? I hate my truck - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2009, 02:13 PM   #1
CountryBoy350
CountryBoy350's Avatar
Default No oil pressure? I hate my truck
Just got a 1994 F150 for $620. First the brake lines, then the springs, the wheels won't come off, and now I have no oil pressure? Well I guess I got what I paid for. My oil pressure gauge goes down to 0 when at idle and back up to normal when I'm driving or when I rev up the engine. Anybody have any idea whats going on? I have a feeling its just the gauge going bad cause my speedometer also acts up from time to time too, but I don't know.
CountryBoy350 is offline   Reply With Quote
Old August 5th, 2009, 03:19 PM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
check the connections on the pressure sending unit, and also make sure your grounds are in good shape, if possible hook a mechanical guage up to see how much pressure you really have, the stock guages arent that reliable
broncobuddha is offline   Reply With Quote
Old August 5th, 2009, 03:27 PM   #3
CountryBoy350
Old August 5th, 2009, 09:48 PM   #4
IDIeselman
IDIeselman's Avatar
+1 They are more of an idiot light than a gauge.
Old August 6th, 2009, 02:50 PM   #5
Daddy Dan
SBF Nut
Daddy Dan's Avatar
If it turns out your rocker just popped off, fix it. Then try that Chemtool cleaner in the oil like I said to break that gunk loose. Put 10w-40 in instead and don't forget a new filter. I bet the pressure comes back up.
Daddy Dan is offline   Reply With Quote
Old August 6th, 2009, 03:11 PM   #6
MiNi Beast
MiNi Beast's Avatar
Did you get that from Broncoholic or his kid AJ Hall?
Old August 7th, 2009, 10:09 PM   #7
CountryBoy350
I'm gonna take off the rocker covers tomorrow and take a look at it. I found out that the guy I bought it from actually did have someone change his oil every 3K miles and that sticker was old. So now I'm trying to find out exactly what went wrong and why I still have no pressure even after replacing the oil sending unit. Remember this oil pressure problem happened 2 days after I changed the oil.
Old August 8th, 2009, 10:27 AM   #8
Daddy Dan
SBF Nut
Daddy Dan's Avatar
Someone correct me if I'm wrong here but all oil in these engines passes through the oil filter, right? Now, if you changed the oil and dirt and gunk broke loose, it may have plugged the oil filter and that could cause a large restriction.
Old August 8th, 2009, 01:22 PM   #9
booblinker
Sore and Tired 24/7
booblinker's Avatar
What engine? I have a 4.9 that does the same thing, the reason it drops to nothing is when it senses less then 5 psi, it drops to 0, kinda like an idiot light but in a gauge. I have ran my for 10k so far, and it still makes no noise, and ran great until I broke something else. As long as you aren't getting noise from the engine I wouldn't worry about it.
Old August 8th, 2009, 05:13 PM   #10
CountryBoy350
Its a 351. It knocks now and it burns a little bit of oil, but I think its just one of the rockers that popped off. When I first start the truck I have full oil pressure then after about 5 minutes it warms up and the gauge drops to 0. The pressure also goes back up when I give it gas.
Old August 9th, 2009, 09:13 AM   #11
Yota Bill
filters have a bypass valve, so if they are completely plugged, the oil will bypass the filter and just not be filtered
if a rocker has "fallen off" it will not really affect the oil pressure, you would have one dead cylinder
it sounds to me like you have wasted the main, rod, and/or cam bearings....the pump produces oil flow, restriction to that flow is what creates the pressure, and the bearings are what creates that restriction...if the gap is too large, then there is less restriction and the oil just falls out without building up to any pressure...the pressure raises with RPM because that is also increasing the speed that the oil pump is turning, which means it is now pushing a higher volume of oil, which cant fall out of the gap between the bearings as fast, so it creates some restriction
sounds like your $620 beater needs a new motor, or a rebuild..or you can go the cheap route and just rol some new bearings into it without doing any machine work, or do a crank kit...got several options, anyway
Old August 9th, 2009, 10:15 AM   #12
Nuggets
I fix stuff!
Nuggets's Avatar
Remove the oil pressure sending unit and screw in a mechanical test gauge. If pressure is still low on this gauge, see Yota Bill's answer.
Old August 9th, 2009, 10:24 AM   #13
luvitmyjeep
broken
luvitmyjeep's Avatar
x2
luvitmyjeep is offline   Reply With Quote
Old August 26th, 2009, 01:06 AM   #14
forfun
forfun's Avatar
if you put 5w30 in it drain it out,replace it with10w40 or 20w50 .a worn motor will need thicker oil to maintain oil pressure
forfun is offline   Reply With Quote
Old August 26th, 2009, 09:20 AM   #15
Broncoholic
Guest
Posts: n/a
Never use 5w30 in a tired engine.
Put in a new Wix filter. Change your oil to 20w50 Valvoline. Put in 2 cans of Restore for V8 engines. Take it out for a 1hr drive. Be sure to put 1/2 quart less 20w50 when you change it.
Park it next day you should have 30+ pressure. I had a 69 302 with Zero pressure, have a fresh 302 on the stand for it. Still driving it everyday, & I run the piss out of it.
Old August 29th, 2009, 02:20 AM   #16
CountryBoy350
I took the motor out of the truck and tore it down since it was knocking, and found out the oil pump seized up, and it spun all the bearings. Gonna be a $500 rebuild. That's just what I need.
Page generated in 0.31570 seconds with 71 queries
