Boat question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2009, 08:52 PM   #1
cj7
Mr. Merrill MI
cj7's Avatar
Default Boat question
I just obtained a slickcraft 19'6"'er, The motor is a 302 V8.
I am told with 4 people on board it runs about 48 MPH.
This thing has to have like a 50 gallon fuel cell.
Will this boat burn through $200 in gas in a weekend?
Mostly this will be a bay and lake fishing boat.
And a tuber pulled here and there.
cj7 is offline   Reply With Quote
Old August 4th, 2009, 09:06 PM   #2
atvextreme
atvextreme's Avatar
only if your running it all day, pulling skiers
I have a 22' searay with a 305 and 50 gal fuel cell
i have only filled it once this year. a good estimate is always 50 cents more per gallon on the water, rather then at the local station.
good guess would be 3-4 hours of run time
atvextreme is offline   Reply With Quote
Old August 4th, 2009, 10:03 PM   #3
badazzamc
Get Some
badazzamc's Avatar
If your towing tubers most of the weekend or running wide open all weekend you could for sure go through $200 worth of fuel.
Old August 5th, 2009, 09:01 AM   #4
tom tom
tom tom's Avatar
if you don't want to burn thru a full tank use some throttle control, seeing this vessel is new to you , it will take a few tanks of gas for you to learn how to run it to get the most useage from a full tank
tom tom is offline   Reply With Quote
Old August 5th, 2009, 04:04 PM   #5
Sol Goode
Obama Nation!
Sol Goode's Avatar
It is not out of the ordinary for me to burn thogh 50 gallons in a couple of hours.
But my boat only has two speeds: full throttle and stopped.
#YOLO
#meballsohard
Sol Goode is offline   Reply With Quote
Old August 5th, 2009, 04:09 PM   #6
greygoose
I'm the dude
greygoose's Avatar
I can use my boat all weekend and only burn thru 20-25 gallons of fuel (1/2 tank) it just depends on how many people are in the boat, if you are pulling tubers, the mechanical condition of the motor and the water conditions. (I have a 351)
Old August 6th, 2009, 11:41 AM   #7
Trail-XJ
Bank Account Understands!
Trail-XJ's Avatar
mine as well!! burned up 50 gallons at the sunsation rally but that was 2 solid days of use running WOT!!
Trail-XJ is offline   Reply With Quote
Old August 10th, 2009, 10:20 AM   #8
Cheap-o-Jeep
I'd plan on around 5gal/hr at full throttle, but you'd be surprised at how long it actually takes to put 10 full-throttle hours on a boat.
Cheap-o-Jeep is offline   Reply With Quote
Old August 10th, 2009, 10:40 AM   #9
greygoose
I'm the dude
greygoose's Avatar
If the boat runs 50mph by your estimate he would be getting 10mpg. I think you are way off base on your estimate.
Old August 10th, 2009, 10:45 AM   #10
dirt poor
dirt poor's Avatar
I have a 3.0 It will burn 20 gallons in 8hrs at full throttle.
dirt poor is offline   Reply With Quote
Old August 10th, 2009, 10:52 AM   #11
Sol Goode
Obama Nation!
Sol Goode's Avatar
I burn 20 gallons an hour at full throttle.
#YOLO
#meballsohard
Old August 10th, 2009, 11:02 AM   #12
greygoose
I'm the dude
greygoose's Avatar
Exactly, so I am sure he would use more than 5gph. I know I use more than 5gph.
Old August 10th, 2009, 11:03 AM   #13
greygoose
I'm the dude
greygoose's Avatar
Page generated in 0.24140 seconds with 62 queries
