4runner build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2009, 09:16 PM   #1
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Default 4runner build
Figured id put this up here. This is my cousin's 4runner we have been building. Trying to get it done for the comp at twisted trails Aug 22, 23
Spec:
37 iroks
dual toy case's with tg twin stick
Trail gear ifs Eliminator Kit - 5in tg springs with dual 5150s upfront , 63" chevy springs with 5150s and creeper joint shackle mounts in the back
Toyota axles - 5.29's with air lockers f&r, 4340 Chromoly Birfields*broke one so now has dirty30s*, and tg creeper gussets
Ceramic High Performance clutch kit
Trail gear rocksliders, and front and rear bumpers with a 12k winch
etc
etc
What we got done the first weekend working on it.
Table of parts
All the ifs cut off and rear suspension off
Front hanger on
Front axle-before
Front axle- Almost done, diff cover hadnt shown up yet
Front hung
My favorite picture And yes it was just for mock up. Going to add tabs to the outside of the shock mounts
Mounting the rear springs using plates and bolts instead of U-bolts. Yes there will be added support
Since i left he's got the motor cleaned up and resealed *22re*, and in. Got the r&p setup. Finished welding up the front stuff. Started welding the rear spring mounts in.Heading back up this weekend with the rest of the parts to hopfully finish it.
Old August 3rd, 2009, 09:20 PM   #2
xj nut
maxin out the 30
xj nut's Avatar
quick question. why is he going with dual 5150s up front?
nice start. ton o money layin on that table lol.
xj nut is offline   Reply With Quote
Old August 3rd, 2009, 09:27 PM   #3
Mud'N'Truck
Wasnt planning on it, kinda just put them both in there cuz we could. Then we just sat and looked at for 5min going so we left it He tends to do alot of jumping and prerunning so we figured way not
We were shooting for a $2500 or so budget. As you can see that didnt last long
Old August 4th, 2009, 04:40 PM   #4
LILL ZJ
LILL ZJ's Avatar
So does he not need my tires anymore? You guys work quick. I was planning on getting over there last weekend to check it out, but that fell through.
LILL ZJ is offline   Reply With Quote
Old August 4th, 2009, 07:47 PM   #5
Mud'N'Truck
No found a good deal on some 37 iroks. Will be out there all this weekend working on it. More hands the better
Old August 5th, 2009, 10:29 PM   #6
xj nut
maxin out the 30
xj nut's Avatar
well the rest of his stuff is in. its just taking up room in jermy's show room lol.
Old August 7th, 2009, 06:22 AM   #7
LILL ZJ
LILL ZJ's Avatar
Yeah i'm sure i'll get over there at some point this weekend. Are you getting up here on friday? Do you need me to bring anything from the shop?
Old August 7th, 2009, 08:06 AM   #8
DUNE JUMP
DUNE JUMP's Avatar
Good setup as long as they are the 5150s valved at 170/60, not 255/70. Check it out-- with the valving for single shock (255/70) doubled at each front corner, that 4-runner will ride like a brick, and if you do manage to compress the shocks while prerunning, they will pack real bad and take forever to extend again.
Dual 5150's at 170/60 is a hot setup for that though
Old August 7th, 2009, 03:51 PM   #9
Mud'N'Truck
Yea im coming up tonight, just waiting for my friend to show up so we can get the parts xj nut is talking about then head up
Old August 9th, 2009, 08:57 PM   #10
LILL ZJ
LILL ZJ's Avatar
well howd the weekend progress go?
Old August 9th, 2009, 09:43 PM   #11
cruiserjg
dodge man
cruiserjg's Avatar
we need pics
cruiserjg is offline   Reply With Quote
Old August 9th, 2009, 09:54 PM   #12
Rattler
Home Sweet Homicide
Rattler's Avatar
Better get to wrenching if you want it for that event!
Nice build so far. More pics too.
Old August 9th, 2009, 11:02 PM   #13
Mud'N'Truck
Just got home. It turned out real sweet. We were out there saturday from 9am to 2am straight threw. Even had pizza delivered to the barn so we didnt have to leave.
I didnt have my camera but my friend got some pictures ill get up later
So yea we got a TON done. Got the front and rear axles all together, all the front and rear suspension and steering done, front and rear bumpers and the winch on, passenger side rock slider, put the trans and dual case's and twin stick together and in, found a bad bearing in the trans when doing the case's so tore the trans down and pieced 2 trans he had together to make 1 good one, locker switch's in and ran air for the front locker.
So we had it sitting on all 4 by the time we went in.
Only stuff really left is to hook up the brake lines, driveshafts, finish mounting the rear shocks, run air to the rear locker, put the other slider on and put the gas tank in
So hopfully will be doing the test run next weekend when i move up and get some miles on it b4 the comp. Also just filled out the entry today so were good to go
Old August 9th, 2009, 11:04 PM   #14
Mud'N'Truck
Originally Posted by cruiserjg View Post
we need pics
I sent you pictures saturday night, you should post it if you got it
Old August 10th, 2009, 07:29 PM   #15
Mud'N'Truck
Alright heres the only picture i have right now. This was taking still early in the night
Old August 11th, 2009, 07:24 AM   #16
DUNE JUMP
DUNE JUMP's Avatar
looks sweet!
Old August 14th, 2009, 09:59 PM   #17
cruiserjg
dodge man
cruiserjg's Avatar
got any new pics
Old August 16th, 2009, 06:20 PM   #18
Mud'N'Truck
Started it today, fired right up. Drove it to the gas station and back and around the yard. Rides real nice. Have to turn the front shocks so the resverors point in, there rubbing on the tires. Heres some pictures from today
With the other toys
Old August 16th, 2009, 09:30 PM   #19
mpsbvp
Hummer recovery team
mpsbvp's Avatar
Send a message via AIM to mpsbvp Send a message via Yahoo to mpsbvp
That bitch is bad ........ i like it nice work
mpsbvp is offline   Reply With Quote
Old August 16th, 2009, 09:55 PM   #20
koochman450r
koochman450r's Avatar
lookin good! did you move up there yet?
Page generated in 0.44687 seconds with 83 queries
