YJ, 8.8 and ABS Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2009, 11:55 AM   #1
The-Bear
Supercharged Santa-Bear
The-Bear's Avatar
Default YJ, 8.8 and ABS Help
I put an 8.8 onto my YJ with ABS brakes. I have bled the system 4 times there is no air in the system. When I am coming to a stop the pedal is softer than the
the old setup. Its softer for about half the pedal travel. Then about half way down my red brake warring light comes on and stays on. When I start up again, if I tap the break pedal about a quarter of the way down the light will go out. Then when coming to a stop it will light up half way down(every time).I also checked the E-brake funcion. It feels like the rear brakes are applying when the the back end is off the ground?
Everything I have read says nothing about a warring light issue. Also every one that had done it says the proportioning valve can stay in with no problems.
I'm thinking I may need a new master cylinder.
I also want the abs back . What do you think about splicing the front sensor wires to the rear to fool the system.
Thnks
Bear
The-Bear is offline   Reply With Quote
Page generated in 0.17658 seconds with 26 queries
