Brake smokin' - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2009, 12:25 PM   #1
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
Default Brake smokin'
So, I put new pads/rotors on the rear of my Denali the other night. I only test drove it up and down my street to make sure that its working. Well, I stop at a stop light today after getting off the freeway on my morning commute and there was smoke billowing (not a little bit, either) out of the wheel wells. It's doing it on both sides of the truck and the wheels are hot enough that you cannot touch them.
Any ideas? I thought caliper sticking, but it's weird that it would be both sides.
All parts were cleaned thoroughly before installation... never seen smoke like this off of brakes outside of a panic stopping big rig.
Old August 3rd, 2009, 12:28 PM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Is it the little parking brake drum on the inside of the rotor? Seems like I had this problem on my 99 Sierra when I did rotors. I'm trying to remember what I did wrong....
Old August 3rd, 2009, 12:29 PM   #3
clarkstoncracker
lol
clarkstoncracker's Avatar
The parking brake is a small shoe on the inside of the rotor. I just swapped mine out.
Old August 3rd, 2009, 12:42 PM   #4
Ridin Dirty
Yeah, that's the one I was talking about. I can't remember what I did to mine. I put it together and it was hanging a bit.
Old August 3rd, 2009, 12:44 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
i think there is only a parking brake on one side on a denali. i could be wrong though. he said it was smoking on both sides.
Old August 3rd, 2009, 01:35 PM   #6
1TFROT
1TFROT's Avatar
pads might be a little too thick. hit them with a belt sander and put them back in. did that with my s10 once (D44 axle) and worked great.
my brakes smoked on my d-max (one rear at a time), but that was because the calipers got bad and started sticking bad.
1TFROT is offline   Reply With Quote
Old August 3rd, 2009, 01:53 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what brand and type of pads did you use? alot of new pads i've put on vehicles have smoked for a few stops till they break in. had a few people come back complaining and i thought something was wrong but it was just the pads being new.
Old August 3rd, 2009, 03:18 PM   #8
Hacksaw
Hacksaw's Avatar
They're Bendix semi-metallic pads.
I'm familiar with the first couple stops smoking.. this was after about 10 miles of freeway and about 2 miles of city driving, with quite a few pretty hard stops on the freeway (I drive like an idiot) and prolly 10 stop lights in town.
I'm not about to grind down the pads with a belt sander, little to ghetto for me.
It's not the parking brake, I looked, it is definitely coming off the pads.
Old August 3rd, 2009, 03:21 PM   #9
s.hembree
s.hembree's Avatar
I'm sure you did, but the slides were lubed properly etc? Those trucks are famous for calipers sticking and hanging up...
Old August 3rd, 2009, 03:38 PM   #10
Hacksaw
Hacksaw's Avatar
Slides lubed?
Old August 3rd, 2009, 04:27 PM   #11
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i think he means the pins that bolt the calipers down. did you clean and grease them? i've pulled brakes off the 99- and newer trucks and the pins usually rust enough to cause sticking calipers. a wire wheel and some brake caliper grease usually fix that problem.
Old August 3rd, 2009, 04:41 PM   #12
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Sounds like the sliders are not sliding. Those are the pins in the caliper that the mounting bolt goes throught. This should slide freely.
Old August 3rd, 2009, 04:43 PM   #13
axxdet
axxdet's Avatar
Send a message via Yahoo to axxdet
Originally Posted by HackSaw View Post
Slides lubed?
yup that's it right there prolly need new calipers now
axxdet is offline   Reply With Quote
Old August 3rd, 2009, 05:01 PM   #14
s.hembree
s.hembree's Avatar
This is what I am referring too... Pull it back apart and take a look. If the inboard pad(piston side) is worn or glazed and the outer looks better then the caliper is not moving properly.
Old August 3rd, 2009, 05:12 PM   #15
Fuel Fire Desire
Mall Crawler
Fuel Fire Desire's Avatar
Slides lubed?
x10
Same thing happened to my camaro. I changed the pads, didnt grease the slides, then on the test drive I got a big smell and lots of heat to the point where I couldnt touch my wheels. I had to torch the calipers to get the slides out.
Fuel Fire Desire is offline   Reply With Quote
Old August 3rd, 2009, 11:56 PM   #16
Rebel2345
NOT GL4x4SucksVideo guy.
Rebel2345's Avatar
Are they dual piston calipers? If so, did you compress both pistons at the same time?
First brake job I did had dual piston calipers, I wasnt aware that you are supposed to compress both pistons at the same time, and they ended up smoking like you describe.
Old August 4th, 2009, 08:22 AM   #17
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Slides lubed?
The shop i work at we always lube the caliper pins and where the pads sit on the caliper bracket!!
Old August 4th, 2009, 10:51 AM   #18
Hacksaw
Hacksaw's Avatar
The cunts at the parts store gave me the wrong pads, its fixed now, no smoke. I made them give me new rotors too since they got summerballsac hot and probably warped.
Nice try, and yes, I always use plenty of lube where the calipers slide.
I was thinking you meant to lube the piston.. I was a little confused on that one.
Old August 4th, 2009, 10:54 AM   #19
clarkstoncracker
lol
I bet you ordered the wrong pads
Old August 4th, 2009, 01:36 PM   #20
Stan
I got a gold chain
Stan's Avatar
His mind is turning to beef brisket.
Stan is offline   Reply With Quote
Page generated in 0.30975 seconds with 83 queries
