trans problems halp anyone? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2009, 11:15 PM   #1
tgk4880
tgk4880's Avatar
Send a message via AIM to tgk4880
Thumbs down trans problems halp anyone?
okay i have a 1995 1500 automatic that i bought about two months ago and was told the trans was rebuilt two years ago. it has a after market trans cooler and a shift kit(u can feel the kick when it shifts). about a month ago i was driving it and the abs light kicked on and then wouldnt shift from first to any other gear. the next day i drove it and that never happened again till today then it started hunting for gears when i was in 3rd then when u gave it gas it just revved (just like the clutch plates were burnt up) then back to 3rd 4th 2nd and so on then when i stopped and went it would not shift out of first, abs light is on only when it does this. and if u let it sit for a while it wont do it for the first ten minutes of driving. and i think it may be a loose wire, it kicked on once when i hit a big bump.
any thoughts?
tgk4880 is offline   Reply With Quote
Old August 1st, 2009, 11:18 PM   #2
Nuggets
I fix stuff!
Nuggets's Avatar
Make, model, engine, 2wd or 4wd would be nice additions if you are looking for help.
Old August 1st, 2009, 11:21 PM   #3
tgk4880
tgk4880's Avatar
chevy 1500 silverado 5.7 4wd and i put a front diff in 2 days before this happened
Old August 2nd, 2009, 10:18 AM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
pinched wire harness somewhere?
Old August 2nd, 2009, 11:57 AM   #5
tgk4880
tgk4880's Avatar
if the wire harness was pinched wouldnt it do it all the time?
Tags
help me, problems, trans, transmission
Page generated in 0.28195 seconds with 38 queries
