Ford F150 wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2006, 10:39 AM   #1
BMFmike
meh.
BMFmike's Avatar
Default Ford F150 wont start
Engine will turn over, but it just wont start, it backfired out what seemed like the intake when we tried it yesterday.
I charged the battery since it was getting low and it really sounded like it wanted to start but just wouldnt.
I know there is a lot of info missing, but post with ideas and I will try them out! Thanks
Old June 22nd, 2006, 11:01 AM   #2
SS
Bananarama!
SS's Avatar
You try starting fluid yet?
If it starts on fluid then you have a fuel delivery problem.. Can you hear the fuel pump click on when you turn the key to the on position?
-Jer
Old June 22nd, 2006, 11:03 AM   #3
BMFmike
meh.
BMFmike's Avatar
Replaced the Fuel pump, but not the filter, will do that next.
Have taken anything apart to get starter fluid down there, I guess that is next as well.
Old June 22nd, 2006, 11:13 AM   #4
Bones
Bones's Avatar
what year/motor?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 22nd, 2006, 11:14 AM   #5
BMFmike
meh.
BMFmike's Avatar
Old June 22nd, 2006, 11:18 AM   #6
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Are there two relays by the air box(or where it used to be)? One of these relays was the engine management relay and the other dealt specifically with fuel. Fords of that model year were notorious for the plugs and the relays going bad.
ckupq is offline   Reply With Quote
Old June 22nd, 2006, 10:51 PM   #7
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Did you pull a spark plug yet? Check one to see if it's fouled. Also check the oil, smell it and see if it smells like fuel.
Old June 22nd, 2006, 10:57 PM   #8
Bones
Bones's Avatar
the truck is probably just pissed it has thornbirds on its feet
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old June 23rd, 2006, 12:22 AM   #9
Tonka
Tonka's Avatar
brother's 90 is sitting out back with that issue. Very common.
Old June 23rd, 2006, 01:28 AM   #10
BMFmike
meh.
BMFmike's Avatar
Yupp.
Old June 23rd, 2006, 08:14 AM   #11
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I am betting on a dropped timing chain. the cam gears are nylon and the material crumbles over time. pop the distributor cap and the number one spark plug and see if the rotor points to where #1 is when you bring the piston to top dead center on the compression stroke.
Yetti
Old June 29th, 2006, 10:27 PM   #12
ckupq
ckupq's Avatar
Its an easy fix, they're dealer parts. I had to do it to mine, but I've seen some butcher jobs on wiring harnesses to fix this litte problem.
Page generated in 0.50894 seconds with 59 queries
