anybody know electric motors? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2009, 01:03 PM   #1
cjric
cjric's Avatar
Default anybody know electric motors?
The motor on my air compressor is acting up. It's a single phase 6hp. I plug it in and it runs for about 5 seconds and blows the 20 amp circuit breaker. I've bypassed the switch, same thing. I've tried a diff circuit, same thing.
The circuit breaker (in the box on the wall) blows before the thermal breaker on the motor does. W/ the covers off I started it up a couple times in the hopes that something would heat up or burn or something and nothing is even getting unusually warm.
Oh, I also unhooked the compressor so there is no load on the motor.
Any ideas?
cjric is offline   Reply With Quote
Old August 1st, 2009, 01:19 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
have you checked the plug and the power cord? i had a tv that would blow the circuit breaker everyonce in awhile, finally one day i smelt smoke and it turned out the plug was shorting out.
Old August 1st, 2009, 01:45 PM   #3
BlooMule
Old School
BlooMule's Avatar
Craftsman?
-rw-rw-rw
BlooMule is online now   Reply With Quote
Old August 1st, 2009, 02:10 PM   #4
shawn
Resident HVAC/R Jambi
shawn's Avatar
check all electrical connections and make sure they are tight. Is ANYTHING getting warm or hot? plug, cord, the wire in the panel going to the circiut breaker? Has anybody been able to test the actual amp draw at the panel? You could just have a bad breaker.
Old August 1st, 2009, 02:42 PM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
My guess is that the motor is shot.
Old August 1st, 2009, 09:01 PM   #6
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Yes.
Old August 1st, 2009, 09:25 PM   #7
Tizken
The start circuit on the motor might not be dropping out when it gets up to speed.
Tizken is offline   Reply With Quote
Old August 2nd, 2009, 05:49 AM   #8
cjric
cjric's Avatar
Plugged it into another circuit and also swapped in another breaker.
Yes, it's a crapsman. 6hp, 30 gallon vertical. About 6-7 yrs old.
How do I check the start circuit?
There are two cylindrical capacitor looking things on it. I'm guessing one is for the starter circuit?
Old August 2nd, 2009, 07:31 AM   #9
shawn
shawn's Avatar
If it starts, then the start circut is working but it might not be dropping out. Sometimes there is a centrifugal switch on the back of the rotor that opens the circuit after the motor starts.
Old August 2nd, 2009, 08:39 AM   #10
BlooMule
Old School
BlooMule's Avatar
That craftsman 6hp () is smaller and draws less current than the 2hp motor on the Dayton compressor I have. Dayton is crap too, but it's 25 yr old crap.
As above, the startup switch may be sticking, or the run capacitor is shot. That motor will cost you almost as much as the whole compressor.
**** WARNING***** Sears Rant!
Craftsman power tools are junk, if you get a couple years out of them you're lucky. For my money, I'll go to flea markets and garage sales and buy 20 year old power tools from Milwaukee or Ingersol Rand before buying new stuff. It's almost all Chinese crap now anyway. Hell, the only time I go to Sears is to replce broken hand tools, which seem to break faster now. Wish I had just repaired my fine tooth ratchets instead of turning them in since they don't make em no more...
-rw-rw-rw
Old August 2nd, 2009, 11:49 AM   #11
cjric
cjric's Avatar
Oh, Im fully aware that Craftsman sucks. I just didnt quite understand that a few years ago. I'm also aware of how much a replacement motor would cost.
I need to take a picture of how this is wired and maybe someone can point out what's what to me. I want to fix this thing and keep it running. I have no desire to go out and replace this just yet. The motor itself seems fine. I'm pretty sure something else has started acting up.
Could the start up switch be the little weighted thing on the back of the shaft? It spins w/ the motor and their is a spring loaded weight that looks like it's designed to move at some point.
Old August 2nd, 2009, 11:57 AM   #12
Broncoholic
Guest
Posts: n/a
Hombre could check it for ya with a 12 ga.
2x is is really a 2.5 hp. Total crap.
http://www.greatlakes4x4.com/showthread.php?t=135433
I got a nice little Curtis for ya Industrial.
Old August 2nd, 2009, 12:09 PM   #13
cjric
cjric's Avatar
very nice, but I'm gonna do all I can to win this battle. :D
Here's a pic of the motor:
The blue wire coming from the cylinder on the left gets kind of warm, but not too bad. The white v shaped switch is controlled by the bronze colored weighted thing on the end of the shaft. If I pull the contact off, it still starts up the same and still blows the circuit.
Old August 2nd, 2009, 12:30 PM   #14
ATOMIC_BADBOY
Shake n Bake
ATOMIC_BADBOY's Avatar
check the amps it's drawing when the motor run's, there should be a tag on the motor that tells you the running amps, if it's to high your motor is junk.
ATOMIC_BADBOY is offline   Reply With Quote
Old August 2nd, 2009, 12:35 PM   #15
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Could be a bad start or run cap also. does the motor actually start up or no? Those capacitors have a lot to do with the motor starting. If it doesn't actually start spinning the start cap is probably bad.
Old August 2nd, 2009, 01:43 PM   #16
Superlifted06FX4
MFC
Superlifted06FX4's Avatar
Send a message via AIM to Superlifted06FX4 Send a message via MSN to Superlifted06FX4 Send a message via Yahoo to Superlifted06FX4
the windings are probably burned up. we just replaced a motor at work for this very same reason.
Superlifted06FX4 is offline   Reply With Quote
Old August 2nd, 2009, 05:55 PM   #17
cjric
cjric's Avatar
It starts up and runs seeming fine. It just pops the circuit (20 amp) after running for about 5 seconds.
Does anyone have a source for these starters and capacitors?
Old August 2nd, 2009, 06:32 PM   #18
BlooMule
Old School
BlooMule's Avatar
If that motor is drawing over 20 amps (let me guess, tag say about 12 amps ) then it's shot.
-rw-rw-rw
Old August 2nd, 2009, 07:00 PM   #19
ATOMIC_BADBOY
Shake n Bake
exactly what I said it's drawing to many amps, check for them on the white or green wire, not sure what one, they both might tell you the same thing.
Old August 2nd, 2009, 07:11 PM   #20
BlooMule
Old School
BlooMule's Avatar
He might not have a 20+ AC amp meter handy.....
-rw-rw-rw
Page generated in 0.48445 seconds with 82 queries
