oil psi ? 318 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2009, 10:08 PM   #1
peanutboozer
LET IT SNOW
peanutboozer's Avatar
Question oil psi ? 318 help
so my old motor was crap. compreshin was form 60 to 103 psi. so I found me a 318 motor to replace my warn out 318. the new 1 is a h.o. cop car motor. I took it home and took it a part new rings, rod and crank barrings, saels,ect..
Know its in the truck and runs good. But I think the oil psi is to LOW. What is the right oil psi at idle and lets go 2K rpm 4 a 86 318 rebilt?
p.s. I cant keep the air out of the tube for the oil gauge I've bled it 5 or 6 time in 400 miles. When I shut it off for the night by morning I got air.
thanks chris
peanutboozer is offline   Reply With Quote
Old July 31st, 2009, 12:52 PM   #2
Flat_Black
The Dodge Guy
Flat_Black's Avatar
sounds like a bad cam bearing. did you replace them?
Old July 31st, 2009, 01:16 PM   #3
rentalrider
rentalrider's Avatar
I agree about the bearing(s). but for reference, I've always been told a rule of thumb for "too low" is less than 10psi for every 1k rpm. ie 30psi for 3k r's. If it's just a wheeler, and you aren't putting many miles/hrs on motor, I had good luck switching to a higher viscosity oil. Just my $.02. Good luck. And if you have any other reason to crack that thing open... replace those bearings.
Old July 31st, 2009, 01:35 PM   #4
buddha
playing life by 'ear'
buddha's Avatar
what year 318? chrysler had a tsb for something regarding low oil psi. like bad sensor, bad ground, can't remember.
i had a 95 zj w/318, dash gauge was always relatively low. but actual under hood was good w/tsb fix.
buddha is offline   Reply With Quote
Old August 1st, 2009, 09:18 AM   #5
peanutboozer
LET IT SNOW
i was hopping i was wrong when i was thinking cam bearing becaese i did not change them.
i do have 10psi for 1k with 10w30 and jest gotsome 30 wight for my 500 mile oil change
10psi @ 650rpm
35psi @ 3k
Old August 1st, 2009, 09:20 AM   #6
peanutboozer
LET IT SNOW
its a 86 and i have all sunpro gauges thanks thou
Old August 1st, 2009, 10:51 AM   #7
deathbypsi
Brian R.
deathbypsi's Avatar
Put a 440 in it
Old August 1st, 2009, 11:08 AM   #8
Freak
Wheelin the HD
Freak's Avatar
I just put rotella T in my 360 Now I need to change the filter, its burning about 4 quarts a week..
Old August 4th, 2009, 01:28 AM   #9
Fraser
Fraser's Avatar
Originally Posted by deathbypsi View Post
Put a 440 in it
i doubt hes got a spare $500+ to pick one up there boss
Old August 9th, 2009, 10:03 AM   #10
peanutboozer
LET IT SNOW
Put a 440 in it
NO BRIAN I've got 2 much money in it now
so when we going wheelin Brian I'm allmost reddy
Old August 9th, 2009, 10:14 AM   #11
peanutboozer
LET IT SNOW
OK up date I've got 60psi in the morning (cold),15psi at idle (650) hot ,and hot running down the road I've got 40psi
I'm happy with the psi but 2 B happy I got 2 run straet 30 oil
Old August 9th, 2009, 10:36 AM   #12
deathbypsi
Brian R.
deathbypsi's Avatar
Bronco ate its trans a month ago so Im starting my 5.0/c4 swap in a couple weeks..........oh,and it might have an exo next time you see it too
Page generated in 0.26575 seconds with 59 queries
