After market fuel injection.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 26th, 2009, 07:18 PM   #1
Freak
Wheelin the HD
Freak's Avatar
Default After market fuel injection....
I'm looking at building my 360 into a stroker, the trans finally died and the motor burned though 6 quarts of oil PDQ so its time for a rebuild. I know if I build a stroker I will need bigger injectors but I want to get rid of the shitty stock ECU all together, put a MSD distributor on it, since it is setup for a distributor, but who makes a fuel injection kit for a magnum 360?
BTW: The motor is in a 95 Ram 1500, but I put this in general because I know some jeeps have them, and other chrystlers.
Old July 27th, 2009, 06:18 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
whats your budget?
Old July 28th, 2009, 06:36 AM   #3
Freak
Wheelin the HD
Freak's Avatar
Not sure, I expect to spend around $1000 for the injection system though.
Old July 28th, 2009, 10:45 AM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Megasquirt... I run it, love it. Plug your laptop in. You can run wideband that controls the fuel to reach your targeted AFR. You have full control of the VE and AFR tables and can wire it to control spark. A lot can be done with this system
Old July 28th, 2009, 11:25 AM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you can also run a holley commander 950 TBi setup. you can feed up to 500 horsepower with that system. only changes to existing engine will be you need a carburated intake manifold and the TBI bolts to it. it's alittle pricey though at 1600 bucks for the full setup including computer and software
Old July 28th, 2009, 12:04 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I would go with the megasquirt because you can tie it into your stock sensors plus your not using a TBI. You all ready have the rail, just purchase bigger injectors... OR you can buy a new pump and regulator and turn the pressure up some. You will have to do the math and figure out how much lb/hr you need and than do more math to see how much psi you need
Old July 28th, 2009, 08:58 PM   #7
Yota Bill
are you actually running this system? I only ask because i have heard lots of bad storeis about it, and wondering if this is still the case, or if Holley has made some changes to thier system
Old July 29th, 2009, 12:57 AM   #8
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
From what i have heard the Projection is the old style analog and the Commander is the digital system. I have witnessed the commander run very well when tuned right.
Old July 29th, 2009, 12:53 PM   #9
Freak
Wheelin the HD
Freak's Avatar
True, how many people are running an aftermarket injection system?
Old July 29th, 2009, 02:17 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I am, I know someone else on here runs megasquirt... do a search and you'll find.
Old July 29th, 2009, 03:17 PM   #11
Dylan
Dylan's Avatar
I have ran megasquirt on a turbo 4.0 2001 TJ. Like stated above its fantastic if you want total control of your motor. Mine being that the stock PCM controls a lot more than just the motor, i have put it back to stock and put the project on hold. If you're looking for a total engine management and only engine management, megasquirt is the way to go.
Old July 29th, 2009, 06:00 PM   #12
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
when i was in school we stuck this on a ZZ502 and it performed very well. stock crate 502 put out like 510Hp with a carb but with way rich AF ratio. with the holley injection we were able to maintain 12.5:1 A/F WOT and it generated 530 HP.
Old July 30th, 2009, 06:04 AM   #13
Freak
Wheelin the HD
Freak's Avatar
My PCM controls all my gauges as well as the motor, but I'm not overly concerned about that, seeing as it will probably get a aftermarket oil pressure, tach, and temp gauges, being a trail rig I wont be overly concerned about the speedo.
Since Ill probably be upgarding the tank to a fuel cell I will probably go with a fresh pump, but a new set of injectors are probably in the line of things to get anyway's with 200K on the orignals.
Page generated in 0.27720 seconds with 62 queries
