Where to plumb in an oil pressure gauge on 97 Dodge 318 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 26th, 2009, 07:34 AM   #1
amundaza
Terminator 2
amundaza's Avatar
Question Where to plumb in an oil pressure gauge on 97 Dodge 318
I want to install a manual oil pressure gauge on my parent's RV, which has a 1997 Magnum 318 engine in it. The stock gauge acts screwy once in a while and I want to make sure that they are getting oil pressure (or not).
I know that the stock oil pressure gauge sending unit is on the top back of the engine block, near the distributor. Is there any other place that I can install the manual sending unit besides there?
Thanks for the input.
Sincerely,
Greg Taylor :) <><
Rochester Hills, MI
1989 Jeep Grand Wagoneer "TRMN8R2"
330-CID AMC Stroker V8
amundaza is offline   Reply With Quote
Old July 26th, 2009, 08:32 AM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
put a tee where the factory ops is. plumb them both from there.
Old July 26th, 2009, 08:40 AM   #3
JeepInABox
In too deep
JeepInABox's Avatar
x2
Old July 26th, 2009, 08:43 AM   #4
curbdog17
Mini Van
curbdog17's Avatar
what i did on my jeep is hook up a mech. gauge where the stock sending unit screwed into the engine and i keep the sending unit in my tool box. that way if that plastic line that comes with your new gauge ever cracks or breaks you can unhook it and put the sending unit back in (no oil leak) The only thing i dont like about the new gauge is I now have a oil line running into the interior of my jeep.(it just makes me a little nervous i would not want to get oil all over my muddy carpet).
Old July 26th, 2009, 09:48 AM   #5
Yota Bill
then go get the copper line kit, it doesnt break or get cut like the plastic stuff does, and its much easier to route.
Old July 26th, 2009, 09:59 AM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
i had the same problem on my old 71 gmc jimmy. i ran the oil line inside of 5/16's fuel line from end to end to protect it.
Old July 26th, 2009, 08:32 PM   #7
amundaza
Terminator 2
amundaza's Avatar
Thanks for the suggestions guys, I'll plumb in a Tee fitting. The idiot light recently started coming on occasionally when we come to a stop light, once warmed up, and I want to make sure that the engine really has oil pressure and if it doesn't, then go from there.
I will definitely spend the extra $10 for the copper line kit ... I've heard horror stories about the plastic lines, especially on AMC V8's, since the sending unit is right next to the exhaust manifold.
Sincerely,
Greg Taylor :) <><
Rochester Hills, MI
Old July 27th, 2009, 08:35 PM   #8
amundaza
Terminator 2
amundaza's Avatar
Default Update on Oil Pressure
Hey guys,
Got the Tee installed today, with a new mech. oil pressure gauge, as well as a new stock sending unit for the dash gauge/idiot light.
Cold start has 54-PSI for oil pressure.
Drove the RV around town, about 9-10 miles and got it warmed up really good. Everything was fine, while driving. Anywhere from 40-50 PSI on the highway (45-60 MPH).
Once it was warmed up, it finally dropped in PSI, when fully stopped, and the idiot light would come on around 7-PSI (at idle). As soon as I hit the gas, the pressure would come back up.
So, the next step I am thinking is to install a new oil pump and see how it performs after that. Any thoughts on this? I assume that the Dodge 318 has the oil pump up inside the oil pan ... is this correct?
Sincerely,
Greg Taylor :) <><
Rochester Hills, MI
Old July 28th, 2009, 12:35 AM   #9
Flat_Black
The Dodge Guy
Flat_Black's Avatar
Originally Posted by amundaza View Post
Hey guys,
Sincerely,
Greg Taylor :) <><
Rochester Hills, MI
yep.
Flat_Black is online now   Reply With Quote
Old July 28th, 2009, 12:43 AM   #10
MilwaukeeF350
Dan
what oil weight you use in that now?
Old July 28th, 2009, 12:48 AM   #11
amundaza
Terminator 2
amundaza's Avatar
Running 10w30 right now. I've considered a swap to 20W50.
Greg
Old July 29th, 2009, 02:41 PM   #12
amundaza
Terminator 2
amundaza's Avatar
Yesterday, I flushed the engine with GUNK-brand engine flush and then did an oil change to 20W50 Valvoline Max Life. We're now running 15-16 PSI at idle, when stopped, once the engine is fully warmed up. No more idiot light coming on. Cruising RPMs has 45-60 PSI oil pressure, once warmed up, depending on RPMs.
This is exactly what I did on the AMC 360 in my Grand Wagoneer, 5 years ago, when it was running 7 PSI at idle warmed up. Got it up to 12 PSI and ran it for about 15,000 miles with 20W50 (Amsoil)
Sincerely,
Greg Taylor
Rochester Hills, MI
1989 Grand Wagoneer "Terminator 2": 330" AMC stroker V8. 4.5" lift 31" BFG A/T's. Killer32 front bumper & DozerII rear swing-out bumper, Water Injection / Hydrogen Injection Coming Soon ... Oh Yeah! And a FISH Carburetor!
Old July 29th, 2009, 02:46 PM   #13
MilwaukeeF350
Dan
Time to rebuilt soon.
what gear ratio in rear axle? I bet rod bearing worn out to copper due work hard.
Page generated in 0.24439 seconds with 62 queries
