1992 YJ driver - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 19th, 2011, 07:36 PM   #41
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I have not had any driveline failures yet, but I don't beat on it either. I'm sure the Detroit locked Dana 35 could be easily broken. I wheel it with good throttle control. Mud and trails basically. The clutch is stock as far as I know with 160k on it. It is chattering when it gets warm though. A clutch will be done soon.probably a stock replacement. I have a pre filter for the k&n and it has been doused pretty good without any problems. I have not changed anything with the disconnect in the front axle. It still works fine. If I remember correctly there is a check valve installed from the factory on the line.
Old December 19th, 2011, 07:50 PM   #42
atvextreme
atvextreme's Avatar
Nice add on,
Now that I saw your pic of that zj, i know where you live and were to close not to have beers.
By now you have had to seen my blazer running up to richards a few dozen times.
if ya ever need a hand let me know.
atvextreme is offline   Reply With Quote
Old February 10th, 2012, 05:33 PM   #43
Rob the plumber
My ax15 started making some evil bearing noise in 5th, and the clutch has been chattering for a year or more so I swapped the Trans. I wad going to convert to an AW4, but I couldn't pass up a brand new free nvg3550 from a good friend, so I did the swap.
I ended up having to fabricate a bracket to hold the transfer case shifter, and also moving the console back a bit, along with cutting the floor/modifying the shifter boot because the 3550 shifter sits back a little further. I also needed to get an external slave bellhousing and a new clutch master/line/slave assembly. O'reiley had them for $120. That's about $100 cheaper than everyone else.
Old February 10th, 2012, 05:45 PM   #44
Rob the plumber
My 2 Jeeps and Starting Lines TJ.
Old March 21st, 2012, 08:40 PM   #45
Jeep ZJ
Jeep ZJ's Avatar
about how much do you figure you have rapped up into the charger add on?? any motor problems yet?
Old March 26th, 2012, 04:26 AM   #46
Rob the plumber
I think around $600 including the methanol kit. I have not had any engine problems at all yet. The wide band is necessary for that. Having to run premium fuel does kinda bite though.
I picked up some tube fenders from Roger on Friday. Nicer than the ones I had.
Old June 8th, 2012, 04:13 PM   #47
Rob the plumber
Running great, but rich!
Old August 26th, 2012, 08:06 AM   #48
Rob the plumber
I put the MTR's on my ZJ and went with some JK Rubicon wheels and 315/70/17 BFG At's. I'm not sure I like the look. I think it looks like a matchbox car. It drives a lot smoother and quieter though.
Page generated in 0.17920 seconds with 48 queries
