1992 YJ driver - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 28th, 2010, 07:17 AM   #21
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Thanks a lot. I get a lot of compliments on the bumper. I think it looks pretty bad ass.
Latest mod.......GL4x4 sticker.
Old March 29th, 2010, 08:22 PM   #22
99tj4banger
99tj4banger's Avatar
hey, i might be mistaken but i stumbled across your build looks good by the way. but i think you bought that diamond plate off me ??
99tj4banger is offline   Reply With Quote
Old March 30th, 2010, 05:53 AM   #23
Rob the plumber
Yes I did! Small world eh??
Old March 30th, 2010, 01:18 PM   #24
99tj4banger
yeah, but that diamond plate looks great along with the jeep nice rig. whats the name of that paint you painted the plate with and where could i possibly get some?
Old March 30th, 2010, 07:47 PM   #25
Rob the plumber
It is an industrial paint from Pratt and Lambert called "tech guard".
Old April 3rd, 2010, 08:30 AM   #26
Rob the plumber
Skinned the tube fenders....
Got the tire carrier mounted and painted.....
Old April 3rd, 2010, 09:35 AM   #27
jeepyj93
Sundowner
jeepyj93's Avatar
Originally Posted by Rob the plumber View Post
Put the tube fenders on. I still have to skin and paint them.
Nice looking tube fenders. They were the first set that I built for my wrangler. They always look better on a red jeep.
jeepyj93 is offline   Reply With Quote
Old April 3rd, 2010, 04:55 PM   #28
Rob the plumber
Thanks! Red and black go nicely I think. Funny how Jeep parts get recycled so much.
Here they are painted and finished. I think I might add a flare to them later though.
Old April 3rd, 2010, 09:04 PM   #29
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
They look a lot better with the new skin.
CHEVYRCKS is offline   Reply With Quote
Old April 12th, 2010, 05:56 AM   #30
Rob the plumber
Thanks, They are strong as hell too. No more crunched stock fenders! I put some TJ rear flares that I picked up from another member.
Old May 6th, 2010, 06:28 AM   #31
ckhanna71
ckhanna71's Avatar
Those tube fenders did turn out nice!
ckhanna71 is offline   Reply With Quote
Old May 6th, 2010, 02:44 PM   #32
drew91xj
drew91xj's Avatar
damn wrangler buld everytime i see on i think i should build one but then i see the to xjs sitting in the yrd and know i cant lol .. jeep looks good i agree with the red and black thing to...
how do you like the clark electric impact
Old December 16th, 2011, 11:09 AM   #33
Rob the plumber
Moar stuff!
Next to my zj
Added a wife mod
Duplicolor bed armored the front bumper. This stuff seems to be holding up great.
Added homebrew supercharger. Eaton m90 from a Thunderbird Supercoupe.
36# injectors
Split second enricher box
2 bar adjustable map sensor
Innovate wideband
Coolingmist methanol injection
cleaned up head
99/up ported intake
Ported throttle body
Stainless header
2.5" exhaust
Flush mount LED tail lights
Cibie spot lights
Threw the hard top and rattle canned full doors on for winter.
Everything so far has been done in my driveway. (including 99% of my wheeling....)
Old December 16th, 2011, 11:22 AM   #34
kmanxj5011
kmanxj5011's Avatar
X2, The whole time im reading through this i think man my axles and junk would be sweet under a yj!!!
kmanxj5011 is offline   Reply With Quote
Old December 16th, 2011, 01:13 PM   #35
judgemikdredd
its a YJ
judgemikdredd's Avatar
this things prety sweet, can you get some more pics of the supercharger set up? how much boost are you running?
judgemikdredd is offline   Reply With Quote
Old December 16th, 2011, 09:35 PM   #36
Rob the plumber
I'll try to get some close pictures tomorrow. It was pretty easy to install. I used the stock a/C compressor mounting holes to secure a plate to mount the blower. I used 1/8" plate. I had to use some spacers to raise the blower high enough for the discharge to clear the valve cover. Line the blower pulley up with the other pulleys, mark, drill holes in the plate and bolt it together. The stock Eaton pulley makes about 5 psi. I bought a smaller pulley that makes about 8 psi. A couple 2.75" couplings and a 90 make up the plumbing.
Installing the blower is cake. Very easy. Tuning it in is where the challenge is.
I used gtp 36lb injectors with increased base fuel pressure and a gtp 2 bar map sensor. I also bought a map sensor voltage adjuster on Ebay to fine tune as best I could.
I tried 24lb injectors, stock map sensor, and an fmu, but it just was not enough fuel.
A wideband o2 sensor is also a necessity. A safe air/fuel ratio under boost is critical.
Old December 16th, 2011, 11:36 PM   #37
judgemikdredd
its a YJ
a map sensor and injectors out of a grand prix gtp? Are the inturnals of the motor stock and are you running stock spark plugs? Hows the afr at wot? I like this idea a lot, hows the preformance gain over stock?
Old December 17th, 2011, 05:24 AM   #38
Rob the plumber
The engine is stock internally. I use champion rc9yc plugs. Ironically they are the same plugs I used in my forced induction 5.0 Mustangs. I gap them @ .032. The enricher module allows a richer mixture under part throttle boost when the computer is still trying to stay in closed loop. It is fully adjustable and I have it set around 13 to 1. Under open loop it drops to about 11.8 to 1 and gets as rich as 11.0 as rpm's climb. I still have the fmu on it and either need to change the disk/ratio or remove it all together.
It has been averaging 15 mpg too. 16 before the blower.
The injectors and map sensor are from a grand prix gtp. Performance is phenomenal. It hauls ass for a big Jeep. I can do 75 on the highway with maybe an inch of throttle. I've raced my 318 zj and a 4.0l tj and absolutely smoked them. It was not even close. I can only guess 300ish horsepower.
Old December 17th, 2011, 09:26 PM   #39
Rob the plumber
Bypass tee made from parts store exhaust stuff.
Simple plate and spacers to mount the blower. I'm still waiting for my "custom" aluminum spacers to be made, so please excuse the booty fab suspension bushing/hardware store spacers...
Brake booster check valve on the ccv line, and a breather in the valve cover to vent the crankcase under boost. The clear tubing to the discharge piping is the methanol injection kit from coolingmist. It works off an adjustable boost switch. I think it is a much better way to intercool a vehicle that makes boost at low vehicle speed over a typical front mount.
Old December 19th, 2011, 06:59 PM   #40
judgemikdredd
its a YJ
this seems prety legit, have any issue with drive line failures yet? Any clutch upgrade? what did you do about the vaccume disconnect on the d30? how does the supercharger handle the mud?
ive never really messed around with any forced inducton my self, but ive read quite a bit on the gm3.8 supercharged
Page generated in 0.33747 seconds with 84 queries
