more power? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 24th, 2009, 01:42 AM   #1
f250mrozi
f250mrozi's Avatar
Default more power?
Ive been noticing since I put slightly bigger tires on the truck im slacking a bit. What can I do to get some more power out of my 5.8?
f250mrozi is offline   Reply With Quote
Old July 24th, 2009, 01:49 AM   #2
boggin-machine
boggin-machine's Avatar
you fucker. u can get on here to post about your truck but not call me back.
Old July 24th, 2009, 01:53 AM   #3
f250mrozi
f250mrozi's Avatar
phones dead in the truck
Old July 24th, 2009, 01:56 AM   #4
boggin-machine
worthless...... you will have a good voicemail to make you laugh.
Old July 24th, 2009, 06:51 AM   #5
MilwaukeeF350
Dan
what gear ratio in axle? 3.55 ? what size tires you put now? It worth to put 4.30 or 4.56 for get back power.
Old July 24th, 2009, 11:36 AM   #6
blackbronco92
300 Inline 6
blackbronco92's Avatar
You'll get more bang for your buck by re-gearing your axles to compensate for the larger tires than to pep up the 5.8L.
There is plenty you can do to the 351 to make it scream, but to get the same effect as a regear would cost much much more.
The general rule is that if you are running a stock 3.55 axle, w/ 33's you should go with 4.10's, and with 35's , 4.56's.
blackbronco92 is offline   Reply With Quote
Old July 26th, 2009, 09:22 AM   #7
masterbeatty
masterbeatty's Avatar
x2 on regear. then headers, intake, efans, and that should wake it up alot, give it a good tune up and advance the timing a bit.
Old July 31st, 2009, 02:19 PM   #8
Broncoholic
Guest
Posts: n/a
I got a 460 for ya should perk it up.
Old August 18th, 2009, 11:57 PM   #9
f250mrozi
f250mrozi's Avatar
what could I do for intake since it has twin air intake pipes?
Old August 21st, 2009, 11:15 PM   #10
Daddy Dan
SBF Nut
Daddy Dan's Avatar
You can go to the junkyard and look for one of these era trucks with MAF. They have a 2 to 1 pipe for the intake. Then slap a good high flow filter on it. Or, you could just leave the factory box in there, and use a good high flow filter. Stock air box with the cold air inlet tube isn't that bad. Its more than these motors need.
How far are you looking to go into this? Whats your budget? I know a lot of inexpensive ways to get a couple hp here and there. But if you want to/can do more, then its not worth your time.
Still got emissions? Check to see if your emissions junk is still operating fine. Those really mess with SBFs when they don't work right. Hell, just check it for codes if your check engine light is on. If theres an issue, your ECU could be in limp mode which really drags a 5.8 down.
If this were my truck, I would do a good tune up(brass terminal cap, good copper plugs), electric fans, 1.7 ratio roller rockers(if I didn't switch the heads for something better first), a good open exhaust system, high flow filter... That would satisfy me for a short while. And I also agree with the above statements to re-gear first.
Daddy Dan is offline   Reply With Quote
Old August 30th, 2009, 11:19 AM   #11
f250mrozi
f250mrozi's Avatar
Im not looking to make this thing a speed demon..just something to satisfy me for the short time being.. going away to iraq in the spring/summer of next year so when i get back its on to better things...such as a f250 powerstroke haha.
Old September 3rd, 2009, 04:40 PM   #12
radhazard1
radhazard1's Avatar
Send a message via MSN to radhazard1 Send a message via Yahoo to radhazard1
Thumbs up
Do your basics first. Intake and exhaust. Better air filter and bigger exhaust. And yes a good tune up as well. Keep it simple
radhazard1 is offline   Reply With Quote
Old September 3rd, 2009, 04:49 PM   #13
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Re-gear would get ya going in the right direction!
Old September 3rd, 2009, 04:51 PM   #14
radhazard1
radhazard1's Avatar
Thumbs up
Gears cost more than a filter and exhaust. Gears are a good thing to do too though.
Old September 3rd, 2009, 05:48 PM   #15
Hoss Blazer
!SPARTY ON!
Ya but when it only gets ya a couple hp more you'll wanna go w/ the gears
Old September 4th, 2009, 11:08 AM   #16
radhazard1
radhazard1's Avatar
Thumbs up
Goes both ways. Lower gears means more RPM's which would work better with better air flow in and out. They want a cheap way to get more and filter, exhaust would be cheaper. And a couple more hp's might be all they need to make them happy too. That's all I'm saying. Of course gears would be a good way to go too and locker(s) as well.
Page generated in 0.41453 seconds with 71 queries
