Valve clearance... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 22nd, 2009, 11:38 PM   #1
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Default Valve clearance...
Working on a KLX650 (big single)
Spec for intake valve clearance is .010 to .019
Exhaust is .015 to .024
I just measured .005 to .006 all around.
I pulled my shims and have the numbers I need in hand to run and get them tomorrow if they are in stock. If they arent, is there a chance I will hurt anything running this weekend with the current setup (maybe 100 miles max?)
Will I see any noticable power increase with the correct clearances?
Thanks!
JcrOffroad
Zoom Zoom!
Old July 23rd, 2009, 07:02 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
You're fine.
Some people like to run them that tight in other engines - and many others never bother even checking
You shouldn't notice anything between the two clearances - what you notice when they get really tight is that it's hard to start (you're losing compression out of leaky valves). The big question is: Is this your first check? Have they moved since the last check? How long between checking?
I'm sure you're fine, but if you notice valves clearances tightening up, it indicates receding valve seats or deteriorating valves. This is just additional info - that motor in your bike is about as bulletproof as they come
Ride that focker no matter what you do with the valves today!
@clarkstoncracker
Old July 23rd, 2009, 10:30 AM   #3
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I had to pull them to get the size anyway, so I left it apart last night. Ran to the Kawi dealer this morning and they traded me for the sizes I needed. Should be all set.
I am not sure if my father ever checked them, and this is my first.
Thanks for the advice sir.
JcrOffroad
Zoom Zoom!
Old July 24th, 2009, 04:18 PM   #4
Ebs
That was cool of your dealer to exchange them let alone have shims in stock. I've become frustrated relying on local dealers to have even basic parts in stock.
Page generated in 0.19736 seconds with 35 queries
