Which 351 do I have? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 22nd, 2009, 09:15 PM   #1
gti3893
gti3893's Avatar
Default Which 351 do I have?
I have a 351 out of a late 60's Mustang, but I am not sure how to tell the difference between the three. Are there #'s on the block that would tell me which one I have? Any help would be appreciated.
Thanks,Bill
gti3893 is offline   Reply With Quote
Old July 22nd, 2009, 09:39 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
if your sure its a 351 then it can be one of 4. the windsor engine has small valve covers with rounded ends. the intake is very narrow next to the carb.
the clevland would have the bigger square covers with a wider intake and the T stat is out the front like the windsor.
351 M/ 400M look the same. the T stat is in the block in front of the intake and the bell housing is squared off on top.
and just on the off chance you found a boss it would have screwed in freeze plugs
Yetti
Old July 22nd, 2009, 09:43 PM   #3
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I don't think the m's came in mustangs
Old July 22nd, 2009, 09:57 PM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I believe the first 351W was available in the 1969 Mustang.
one source:
http://www.theautochannel.com/vehicl...f69mcont.frame
@clarkstoncracker
Old July 22nd, 2009, 11:05 PM   #5
sandguy356
bronco built for fun
sandguy356's Avatar
More than likely its a 351W, if it has 302 like valve covers it is for sure. Post a pic and we can give you a for sure answer.
sandguy356 is offline   Reply With Quote
Old July 26th, 2009, 09:53 AM   #6
Broncoholic
Guest
Posts: n/a
If it is a C8 or C9 in the3 casting number it is a 68 or 69 block, the casting numbers are on the block just above the starter, If you have a Pent roof valve cover it is a Cleveland.
Post picts & decode the casting number.
Pull the valve cover to see if you have early 351w heads, they are the best, Look for a larger WF in the galley between the valves & Push rods, & 351 on the right side in the top of the head. Those are the small chamber 60cc with the large valves. The heads that came on the 4bbl Mach I's.
Old July 28th, 2009, 11:36 AM   #7
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
most likely a W if its in a early mustang
84mudder is offline   Reply With Quote
Old February 13th, 2010, 03:57 PM   #8
blade262us
blade262us's Avatar
Default Identification
Absolute easiest way to tell the difference is the 351W is the only one that the upper radiator hose comes straight out of the INTAKE manifold the others come straight up out of the block . That being as long as you know its a 351 .
blade262us is offline   Reply With Quote
Old February 13th, 2010, 09:23 PM   #9
V8 BroncoII
Buckin Bronco
V8 BroncoII's Avatar
Clevelands did not come out til 70 so if it was an original motor in a 69 it has to be a W.
V8 BroncoII is offline   Reply With Quote
Old February 13th, 2010, 09:41 PM   #10
V8Mustang1967
V8Mustang1967's Avatar
69s had everything 70 had... so it between 351 Cleveland or 351 Windsor. easy way to tell is the 351C is very large compareable sized to a Big Block so it would look stuffed. If its 351W it will be around the same size as a 289/302 since the 351Windsor heads can fit on the 289/302s
V8Mustang1967 is offline   Reply With Quote
Old February 13th, 2010, 10:23 PM   #11
V8 BroncoII
Buckin Bronco
I am a moderator over at ShelbyForums.com and know for a fact that there NEVER was a Cleveland from the factory in a 69 Mustang. This was a popular swap in the 70's when Cleveland's where plentiful in junkyards and the fact that motor mounts and bellhousing patterns are the same between W's and C's.
Old February 13th, 2010, 10:30 PM   #12
V8 BroncoII
Buckin Bronco
If the thermostat is in the block it is a Cleveland
If the thermostat is in the intake it is a Windsor.
Page generated in 0.29154 seconds with 59 queries
