Michigan's First, Formula Toyota #095 build up *updates 11/13, pg3* - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 31st, 2009, 10:37 AM   #21
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
second row seating needs work, it seems a bit unsafe.
Why a steel dash and alum floors? Seems like it'll be all one or the other.
Old July 31st, 2009, 11:23 AM   #22
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
So the dash could be easily welded in I'm assuming...
And aluminum makes the floors lighter. Is that weird?
Nuzzy is offline   Reply With Quote
Old July 31st, 2009, 11:53 AM   #23
outback20
Outback 20
outback20's Avatar
Very cool build, I look forward to see the progress.
x2
outback20 is offline   Reply With Quote
Old July 31st, 2009, 01:09 PM   #24
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I only ask because it seems if weight is thought, then it'd be use as much alum as possible, or if not, then use sheetmetal. Throwing a couple of tabs on the dash cross bar to make a bolt-on alum dash would be an easy solution, so just trying to see the thought process behind it.
Old July 31st, 2009, 03:00 PM   #25
chevotass
chevotass's Avatar
and being able to remove that said dash if it was alluminium and bolted in would be easier and lighter.
should be a fun build for you guys. what tires/wheels is he going to run?
Old July 31st, 2009, 06:23 PM   #26
brimy311
Smells like a Fork Liftis
brimy311's Avatar
We wanted something a little different for the dash, that we would not be able to pull off with aluminum. There is no reason on this Ftoy to have to remove the dash, as there will be hardly anything under the dash. We need this to be somewhat water tight to protect some of the stuff we will be installing.
He is going to run my Allied Beadlocks and Krawlers.
JcrOffroad.com
Like us on Faceook!
Old July 31st, 2009, 08:00 PM   #27
Originally Posted by 4Bangler View Post
Looks like all the "added bars" were tiny square tube from Home Depot...bootylicious....I'm you guys will find a way to pretty it up.
Not really. 1" square for the side bracing and floor structure is normal and what Hendrix recommends. It puts the flat of the square about 3/8" countersunk from the main 1.75" side tubes, lets the side panels be flsuh or slightly recessed.
I regret not building the F-toy clone that I had bent up.
Old September 2nd, 2009, 08:10 PM   #28
brimy311
brimy311's Avatar
Well we finally get back to work on this thing. Today we desgined, cut and bent the new front and rear crossmembers:
3/16" steel. We used 1" bottom die opening dies to bend it, took every bit of the 60 tons of pressure our press had :smokin:
I cut out the rear crossmember and installed the new one:
Close up of the font:
I started playing with shackles and stuff, but here is how I leaving it for the night:
Also cut out the front hanger/crossmember in anticipation of the new stuff going in soon!
JcrOffroad.com
Like us on Faceook!
Old September 8th, 2009, 12:50 PM   #29
trailrail302
Im going FAST!!!
trailrail302's Avatar
Lookin good!!!
trailrail302 is offline   Reply With Quote
Old October 1st, 2009, 01:48 PM   #30
brimy311
brimy311's Avatar
Back to work on this thing! Plan to try to go wheeling somewhere south in November, so I want to get this done to take it.
Here is the front crossmember/spring hanger/winch plate
Rear Shackles and corner panel thingies
more to come!
JcrOffroad.com
Like us on Faceook!
Old October 1st, 2009, 02:00 PM   #31
KartRacer
Blowd up
KartRacer's Avatar
Those pieces look good. Very nice how it all came together.
Old October 1st, 2009, 02:58 PM   #32
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Great work!
Old October 1st, 2009, 05:07 PM   #33
trailrail302
Im going FAST!!!
rear shackles are sexy!!!
Old October 1st, 2009, 05:24 PM   #34
funandgames
funandgames's Avatar
Nice work
funandgames is offline   Reply With Quote
Old October 1st, 2009, 05:51 PM   #35
TruckU
Xj'in all day
TruckU's Avatar
yeah this thing is lookin sexy already
TruckU is offline   Reply With Quote
Old October 2nd, 2009, 12:26 AM   #36
Mclovin
"The Situation"
Mclovin's Avatar
those shackles are SICK ! I dont think i've ever seen them done like that
Old October 2nd, 2009, 01:27 AM   #37
creeping death
I'm that guy.
creeping death's Avatar
he said sick
nice work fellas. keep postin those pix!
Old October 2nd, 2009, 03:19 AM   #38
VonDirt
VonDirt's Avatar
nice work, looking good -
those signature crossmembers look like a product
VonDirt is offline   Reply With Quote
Old October 2nd, 2009, 03:47 AM   #39
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Originally Posted by brimy311 View Post
....3/16" steel. We used 1" bottom die opening dies to bend it, took every bit of the 60 tons of pressure our press had :smokin:.....
Hmm...the shops at my work form 7ga. all the time, bends like butter, I'll double check the tonnage they are running, but you may have a hydraulic problem. I just did a job with some formed 3/4" Plate, with a bend line 96" long...now that's some tonnage!
Either way, damn nice work, what are those shackles going to look like at ride height and full stuff? Seems like the spring may contact the crossmember at full stuff.
Old October 2nd, 2009, 06:24 AM   #40
brimy311
brimy311's Avatar
1" V bottom die opening is WAY too small. It was not "air bending" as much as "die forming". We didn't have enough 2" V bottom die opening length to bend these, which would have made it easy. On the 1" bottom die, it requires 19.1 Tons per foot, where as the 2" bottom changes that to 9.5 Tons per foot. Big difference! The crossmembers were like 43" long, so just beyond the 60 Tons of pressure the press has. Trust me, this press is no slouch!
JcrOffroad.com
Like us on Faceook!
Page generated in 0.46679 seconds with 83 queries
