Jeep being pulled by tow bar questions! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2009, 08:29 PM   #1
Theidt88
Boggers boy
Theidt88's Avatar
Send a message via AIM to Theidt88
Default Jeep being pulled by tow bar questions!
Hey guys, anyone experienced knwo for sure what gears i keep the jeep in. Do i keep transfercase in neutral and put trans in 1st! Thats what iv heard but want to double check! Thanks
Theidt88 is offline   Reply With Quote
Old July 21st, 2009, 11:27 PM   #2
Nuggets
I fix stuff!
Nuggets's Avatar
T-case in neutral.
Flat towing a vehicle sucks ass. I know you are doing it because you don't have a trailer but I would suggest you save up for one. Be careful with sharp turns and stopping. Don't even think of trying to back up while the towed vehicle is hooked up.
Good luck.
Old July 21st, 2009, 11:39 PM   #3
blue thunder
blue thunder's Avatar
you can rent one for 50 bucks go to mtec of some random rental place uhaul and such
blue thunder is offline   Reply With Quote
Old July 22nd, 2009, 12:02 AM   #4
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
depends on the trans and t case. most are like you say but some still aren't supposed to be towed more then 50 miles do to lack of oiling, if it was me and when i flat towed i took the extra 20 min and pulled the axle side part of the shaft and taped up the u joints so the caps didn't fall off and wired it really good so i didn't have to worry about cooking a trans because i didn't want to pull 8 bolts
scramblerman72 is offline   Reply With Quote
Old July 22nd, 2009, 09:25 PM   #5
Theidt88
Boggers boy
Theidt88's Avatar
from the blogs i have read if you put the t/case in neutral "obviously" and trans in 5th it gets the oil distributed throught the trans from the oil slinger or something along those lines and i only have to go 4 hours stopping at west brand for 20 minutes. So 2 on break and 2 more to mackinaw. Hopefully this works, we tried it out yesterday with my self rigging and it turned out pretty damn good with turning, breaking, and everything else along those lines. I believe with my brand new wheel bearings, heavy duty tie rod and drag link this will be as simple as abc's, but ill knock on wood at the same time! Thanks for you opinions and ill post some pics from the youper trip and back trails of 1000 miles!!!
Old July 22nd, 2009, 10:06 PM   #6
Nuggets
I fix stuff!
Nuggets's Avatar
Good luck, be safe.
Old July 22nd, 2009, 10:09 PM   #7
MiNi Beast
MiNi Beast's Avatar
X2 how hard is it to pull the shafts? It's your ass and money if you jack shit up cause you to lazy to pull the shafts. I rather be to careful then anything. To many wicked stories.
Old July 23rd, 2009, 12:34 AM   #8
sodapop
Support the Sport!
sodapop's Avatar
x$75 for a junk case and multiple man hours to rebuild the exploded one....
If I can offer you any advice at all for flat towing it's this,
FOR THE LOVE OF ALL THAT IS GOOD AND HOLY, PULL THE DRIVE SHAFTS!
some pics for you to reference:
When I went to pull the t-case out of the jeep, I literally pulled the case out in 2 pieces. It fell apart in half.
Story:
Cruising north on I-75 at about 65 miles per hour, the t-case jumped into gear and EXPLODED the t-case in half. At first, I thought it was a bearing failure, but they were all good. It hit so hard, that it actually bent the front output shaft, which I thought was pretty impressive considering it's over an inch thick and only about 6 inches long.
Pulling the driveshafts will take you 20 minutes, it's only 4 bolts at each yoke and you can bungee or zip tie them up.
This one ended my wheeling trip before it began, bummer for the kids who spent about 6 hours in the jeep and didn't get to wheel.
Old July 23rd, 2009, 01:12 AM   #9
MiNi Beast
MiNi Beast's Avatar
Yeah I remember when you did this, you are who I always refer to when people ask about flat towing.
Hard lesson learned right there!
Old July 23rd, 2009, 10:41 AM   #10
Nuggets
I fix stuff!
Nuggets's Avatar
Buy a trailer.
Old July 23rd, 2009, 10:48 AM   #11
Broncoholic
Guest
Posts: n/a
Pull the shaft, ^^^ I ahve a trailer for rent///
Old July 23rd, 2009, 11:06 AM   #12
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
pull the shafts
Old July 25th, 2009, 10:37 PM   #13
jared
Can't Worry About It
jared's Avatar
i use a car dollay and pull the rear shaft.
we got a brand new dolly for 800 bucks a couple years back, and use it all the time. worth every penny
jared is offline   Reply With Quote
Old July 26th, 2009, 12:59 AM   #14
xjmichigan
xjmichigan's Avatar
I use two car dollies
Old July 26th, 2009, 02:32 AM   #15
sodapop
Support the Sport!
sodapop's Avatar
You ain't shittin' I brought the fail hard for that trip. It was one of those, "I don't need to pull the shafts, I've never had a problem......" things. It was helpful in explaining to the wife why I needed to buy a car hauler.
I won't ever flat tow again and now I don't have ta!
Old July 26th, 2009, 02:34 AM   #16
sodapop
Support the Sport!
sodapop's Avatar
I bought my car hauler off craigs list for $700, put another $125 in registration and new lights and I'm golden now. Some people swear by car dollies and to each their own, but it's alot of money you can use towards of car hauler. They are much smaller to store though.
Old August 13th, 2009, 06:14 PM   #17
PeteC
Get Up and Go
Blowing up a t-case does suck
94 YJ and 00 TJ
Flat towed behind the RV for combined thousands of miles.
Auto trans in Park, T-case in neutral, key in "on" position on the 94 (Owners Manual Instructions)
Manual trans in 1st, T-case in neutral, key in "on" position on the 00 (Owners Manual Instructions)
Never had any problems.
We have towed it behind a Durango and the Commander. Durango did OK, except braking was over taxed. Commander, well, I won't be doing that again.
The RV was a Class A weighing in at 17,500# dry.
PeteC is offline   Reply With Quote
Page generated in 0.40848 seconds with 74 queries
