2002 Chevy Zr2 no 4x4? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2009, 02:27 AM   #1
zhart09
Default 2002 Chevy Zr2 no 4x4?
Iam thinking about buying a 2002 Zr2 pickup but the 4x4 dosent work sounds like it is locking in but front wheels do not spin what could be the problem...Hopefully not the T-case
zhart09 is offline   Reply With Quote
Old July 21st, 2009, 03:06 AM   #2
boggin-machine
boggin-machine's Avatar
check that its engaging all the way. ive seen a few of these with bad vacum engagement that wouldnt engage it all the way and would just nick the gears.
Old July 21st, 2009, 10:13 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
jack up one front wheel with the truck in 4wd. spin the tire and see if the front driveshaft spins. that will tell you if it's t-case or front axle.
Old July 21st, 2009, 10:16 PM   #4
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Vacuum is often a problem on the ZR2's. I would check out ZR2USA.com they have tons of information specific to your truck.
JohnL is offline   Reply With Quote
Old July 23rd, 2009, 08:57 AM   #5
DUNE JUMP
DUNE JUMP's Avatar
don't the 4x4 switches go bad on these all the time?
Old July 23rd, 2009, 12:49 PM   #6
Disturban
Disturban's Avatar
If the switch is bad it will blink...if it is not blinking more then likely it is either the Vacuum actuator that is located under the battery tray or the Transfer case vacuum switch. 99% of the time no 4x4 is the actuator, they are just a rubber diaphragm that pulls the cable to lock in the front axle, once these crack from dry rot no more 4x4.
Page generated in 0.32852 seconds with 41 queries
