project 5.0 one ton tj - Page 15 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2010, 10:42 AM   #281
firehawk
Live Action!
firehawk's Avatar
Originally Posted by bigbchevy View Post
ok i m going to try to go to bundy hill tomorrow im still trying to work some bugs out. i have a prob with the mass air when its pluged in and i start it it runs for a sec and then dies . if i on plug it it runs ok and will stay running ! i dont know wtf is going on with it
Do you have the right sample tube for your injectors? It goes in the mass air meter.
Old March 12th, 2010, 02:05 PM   #282
bigbchevy
missmrgreenagain
bigbchevy's Avatar
im not sure . ford racing told me to check the fuel pressure reg that it may be bad
H.o.r.e
Old March 12th, 2010, 02:09 PM   #283
firehawk
Live Action!
firehawk's Avatar
Do you have a fuel pressure gauge?
I think you want about 44 psi if I remember correctly.
Old March 13th, 2010, 06:06 AM   #284
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ok we got her all fixed up now its time to check it out!!
H.o.r.e
Old March 13th, 2010, 08:34 PM   #285
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ok well it did good for the first run had a prob with the charging but other then that it was good
H.o.r.e
Old March 13th, 2010, 08:40 PM   #286
kickstand
circling the drain
kickstand's Avatar
this jeep is still gay
Old March 13th, 2010, 08:42 PM   #287
bigbchevy
missmrgreenagain
bigbchevy's Avatar
no your gay! what were you doing today?
H.o.r.e
Old March 13th, 2010, 08:51 PM   #288
kickstand
circling the drain
kickstand's Avatar
took xander up to splash city in frankenmuth.
Old March 15th, 2010, 11:09 PM   #289
Impact
Looking good :)
I was wondering if you could post some pictures of the front axle and it's mounts. Mostly though of the the driver side coil mount and the lower control arm mount.
Are you running some kind of aftermarket short on the front?
Impact is offline   Reply With Quote
Old March 16th, 2010, 09:03 PM   #290
bigbchevy
missmrgreenagain
bigbchevy's Avatar
i will try to get some pics when i get a min .
H.o.r.e
Old March 19th, 2010, 11:12 AM   #291
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by Impact View Post
Looking good :)
i mounted the coil on the spring plate so on the pass side i got a one inch lift spacer for the coil to level it out and i had to modify the lower link because it is half on the tube and half on the housing . but all in all it works great!
H.o.r.e
Old March 19th, 2010, 12:04 PM   #292
fullthrottle
2013 King of da Moustache
fullthrottle's Avatar
Send a message via AIM to fullthrottle
hows the alt issue!? whats going on with it?
fullthrottle is offline   Reply With Quote
Old March 19th, 2010, 12:17 PM   #293
bigbchevy
missmrgreenagain
bigbchevy's Avatar
still not sure i got the bat and alt tested and they came back good so now im going to see what i can track down
H.o.r.e
Old April 12th, 2010, 06:41 PM   #294
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ok i got it running rite now it had some vac leaks . now i just need to find out why when i plug my alt in it kills the motor ?
H.o.r.e
Old May 15th, 2010, 08:04 PM   #295
sjhenderson18
MEMBER
sjhenderson18's Avatar
Alternator issue is fixed . . . at least on mine. we just need to copy cat it onto Scotts now!
sjhenderson18 is offline   Reply With Quote
Old May 15th, 2010, 09:25 PM   #296
bigbchevy
missmrgreenagain
bigbchevy's Avatar
bbk fuel pre reg fixed my motor prob now she runs great!
H.o.r.e
Old July 22nd, 2010, 07:18 PM   #297
bigbchevy
missmrgreenagain
bigbchevy's Avatar
ok well had lots of lil problems with it now all is good. thanks to pigfat!
H.o.r.e
Old July 22nd, 2010, 08:08 PM   #298
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
And???
Old July 22nd, 2010, 08:28 PM   #299
bigbchevy
missmrgreenagain
bigbchevy's Avatar
lets see i had a bad distrib it was shorting out cause it was so worn out. the o2 sen were put on the wrong sides so the left was telling the right what to do and right was telling left lol not good . ...... the comp was to close to the bat and alt so it was picking up stray volts. ......the comp was also messed up and had to put a new one in ........... and had a power wire meltid to the header but other then that it was fine haha
H.o.r.e
Old July 22nd, 2010, 11:38 PM   #300
pigfat
GONE COMMANDO
pigfat's Avatar
glad i could help, see you at the pig gig.
pigfat is offline   Reply With Quote
Page generated in 0.30387 seconds with 84 queries
