Xenon HID headlights - for all vehicles - can even do sealed beams - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2009, 12:02 AM   #1
BooGTS
Boost Withdrawl
BooGTS's Avatar
Default Xenon HID headlights - for all vehicles - can even do sealed beams
In addition to my dealer thing (see member owned business section), I'm selling HID's. If you have a CJ,YJ,or TJ, you'd have to get a conversion kit (I can point you in the right direction) so that you could put a bulb in them (versus a sealed beam), but JK's, ZJ's, WJ's, most everything non-jeep made after 1990, I should be able to hook you up. I can post pics of what I did with my XJ if there is interest.
Specify Make, model, year, and color you'd want (5000K is bright white, 6000K is bright white with a tinge of blue). I can get anything from 3000K to 10000K, but 5-6k is typical. Anything above 8K and you've gone to blue/violet and it diminishes light output. I'm likely only to have 5000K and maybe 6000K in stock, but ask if you want anything else - I might have it.
-Ryan
Prices:
35W low beam only w/ slimline ballast: $90
35W low and high beam w/ slimline ballast: $130 (only single headlight vehicles, if your high beams are in a separate housing and you want high beams as well, you have to buy two kits)
50W low beam only: $120
50W low and high beam w/ slimline ballast: $150 (again, only single headlight vehicles, like TJ's and XJ's, not like Chevy trucks for example)
*I'd only recommend using 50W in glass housings or daylighters as they do get fairly hot. 35W is more than adequate for the street.
Conversion kit for sealed beam headlight systems: add $50.
Daylighter install went great - customer said they lit the trail for a mile!
BooGTS is offline   Reply With Quote
Old July 21st, 2009, 06:56 AM   #2
kmanxj5011
kmanxj5011's Avatar
Id be interested in the XJ kit. Got pics?
kmanxj5011 is offline   Reply With Quote
Old July 21st, 2009, 08:37 AM   #3
BooGTS
Boost Withdrawl
BooGTS's Avatar
I can get you the headlight conversion set for $50, then you'd be set to accept the HIDs
I don't have a picture of the full kit, I was too excited to get that installed. I will get a shot with my next order. Comes with everything needed:
2 ballasts, all wiring, and 2 bulbs. 2 new bulbs run $35 if you want spares. I'd replace them both at the same time if one goes out as they seem to change color slightly over time.
NOTE: the ballasts shown are the "slimline" ones and those are $120. Standard kits have a square stamped steel housing. It takes up a little more room, but most vehicles should be ok, there is enough wiring provided.
Old July 22nd, 2009, 10:21 AM   #4
kmanxj5011
kmanxj5011's Avatar
so 50 bucks is everything of just the new housings?
Old July 23rd, 2009, 05:31 PM   #5
BooGTS
Boost Withdrawl
BooGTS's Avatar
Like I said, $50 would get you the housings, then you'd be ready to accept the HIDs.
So $50 + $100 for the HID kit ($150 total) would convert your XJ from Sealed beam halogen to replaceable bulb Xenon.
Old July 27th, 2009, 11:41 AM   #6
BooGTS
Boost Withdrawl
BooGTS's Avatar
ttt
Old July 27th, 2009, 11:52 AM   #7
steelhd1
Hypnotized
steelhd1's Avatar
I may be interested. Will pm you later
steelhd1 is offline   Reply With Quote
Old July 27th, 2009, 11:55 AM   #8
Bishop
Bishop's Avatar
i know you want to see what your old rubi would look like with them
Old July 27th, 2009, 01:56 PM   #9
BooGTS
Boost Withdrawl
BooGTS's Avatar
PMs sent.
Old July 27th, 2009, 06:10 PM   #10
Bishop
Bishop's Avatar
what did you put in the picture showing them. 5k or 6k?
also. do they have low beams and high beams?
Old July 27th, 2009, 11:31 PM   #11
BooGTS
Boost Withdrawl
BooGTS's Avatar
6k is in the pic. They are low Xenon, high halogen. I can get them "bi-Xenon" with both. They are $35 more, so I didn't even bother offering until you asked.
edit: Went out to get some night time pics - saw a white and black fluffy tail go under the Jeep. Decided it wasn't worth the risk - I'll get pics tomorrow night...
Old July 28th, 2009, 09:57 PM   #12
BooGTS
Boost Withdrawl
BooGTS's Avatar
These are with 6k bulbs and you can see the blue - 5k is more OEM. I think I'm going to bring the aim pattern down. Better yet would be to mark out an aim pattern and recal them, something I'll do when I put the e-codes in.
Old August 3rd, 2009, 04:56 PM   #13
BooGTS
Boost Withdrawl
BooGTS's Avatar
Awaiting my first round of TJ lights to come in. Will post pics if I remember to take them.
Old August 3rd, 2009, 05:12 PM   #14
Shuie07
Shuie07's Avatar
how much for the tj setup
Shuie07 is offline   Reply With Quote
Old August 3rd, 2009, 10:56 PM   #15
BooGTS
Boost Withdrawl
BooGTS's Avatar
$150 installed for the standard ballasts. This includes the 7" E-code conversion kit and H4 bulbs of your temperature preference.
Stock OEM is 4300K, thats why I usually recommend 5000k, but 6000K is the blue look some people desire. Price is the same nomatter what color you choose.
Old August 4th, 2009, 02:54 AM   #16
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
I've got a bit of a strange question;
Would you be able to get your hands on H3 HID conversion kits?
I think it would be really interesting to convert a couple standard KC or Hella housings, and that price sure as hell beats the cost of a pair of HID off road lamps.
1988JeepXj is offline   Reply With Quote
Old August 4th, 2009, 07:18 AM   #17
BooGTS
Boost Withdrawl
BooGTS's Avatar
Sure can. The only issue I could see with those is depending on where you mounted the KCs, you would have to lengthen the wiring. Right now there is only about a foot between the bulb and the ballast. I'd recommend getting the slimlines as they're easier to mount and seemed to be better sealed - though I'm sure both are waterproof. Like anything electronic, I'm not about to powerwash them, however.
Old August 6th, 2009, 12:18 AM   #18
BooGTS
Boost Withdrawl
BooGTS's Avatar
Here are the conversion housings for the TJ, in case you're wondering what I'm talking about. The XJ ones are similar - but rectangular obviously.
Old August 6th, 2009, 08:15 PM   #19
BooGTS
Boost Withdrawl
BooGTS's Avatar
Heres some pics from todays TJ intall. Xenon on left, stock halogen on right.
Next pic doesn't show much - other than the color difference. These are 5k Xenon, close to OEM.
Old August 8th, 2009, 05:28 PM   #20
BooGTS
Boost Withdrawl
BooGTS's Avatar
Bump. Submitting new order monday.
Page generated in 0.34791 seconds with 83 queries
