2000 banshee popping from exhaust - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 19th, 2009, 11:06 AM   #1
kargod
Charcoal Mellowed
kargod's Avatar
Default 2000 banshee popping from exhaust
My 2000 banshee with no mods whatsoever has begun popping under hard accel from the right side cylinder. I pulled that carb apart and cleaned / rebuilt it with no change. I don't have an accurate comp tester up here at the cabin, but my shitty hf one shows both being even but it always reads low. I got around 90 psi on each cyl cold.
If I pull the choke, engine bogs as normal but no pop. It is kind of a foo-POP! Right off idle.
Quad has fresh gas, tank looks clean, and it has a newer air filter. Spark plugs are also new.
Any suggestions would be greatly appreciated. Oil burners and I have never gotten along...
kargod is offline   Reply With Quote
Old July 19th, 2009, 11:53 AM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
Sounds like low compression.
Old July 19th, 2009, 09:27 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would check the tech section over at www.bluetraxx.com if they don't have the answers they can't be had.
Yetti
Old July 19th, 2009, 11:32 PM   #4
kargod
Charcoal Mellowed
kargod's Avatar
I can't hear you NANANANANANANANA!
Yetti I will try them.
My 'shee only has around 9 good runs on it. I want to pretend that they are reliable.
Old July 19th, 2009, 11:38 PM   #5
hondadirtracer
Skymaster
hondadirtracer's Avatar
http://www.bansheehq.com/forums/
Try this site too.
hondadirtracer is offline   Reply With Quote
Old July 19th, 2009, 11:39 PM   #6
motocrosstcw
motocrosstcw's Avatar
lol i second the compression or you have a leak somwhere does it smoke really bad or load up any?
motocrosstcw is offline   Reply With Quote
Old July 20th, 2009, 07:28 AM   #7
Yetti
Yetti's Avatar
I figured you needed "Good" advice as apposed to guesses. banshee's a wreched thing to screw with when they are acting up.
Yetti
Old July 30th, 2009, 03:35 PM   #8
BIGONTS
I'm 99% certain it's the compression. Might be low on one or either side. Bettter to fix it sooner so you don't have to buy new pistons and head due to damage. You might get away just honing it and getting new rings.
BIGONTS is offline   Reply With Quote
Page generated in 0.18837 seconds with 47 queries
