Axle Part(s): ARB-Currie High Pinion 3rd member 9 inch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 17th, 2009, 06:19 PM   #1
Ls1xj
Default ARB-Currie High Pinion 3rd member 9 inch
ARB 31 spline Currie High Pinion 9 inch 3rd member. This will fit any 9 inch housing. It has 4.56 gears but you will need to regear as it has a broken tooth on the ring gear. I'm not sure how the tooth got broke. I did not know it until I took it out and saw the tooth laying on the garage floor. You probably need a different ratio anyway. I have axles that are stock length for a 96 XJ. Alloy axles from M/E that are included.
I believe this unit sells new for around $1800.00
I'm selling for $745.00
ID:	46369   Click image for larger version
ID:	46370   Click image for larger version
Ls1xj is offline   Reply With Quote
Old July 17th, 2009, 06:56 PM   #2
Tab
Tab's Avatar
Your the guy from UA right? You probably broke it climbing the rock climb in the scramble area at Rocks and Valleys that only 3 other people made. Good luck with the sale, thats a great price.
Old July 17th, 2009, 07:33 PM   #3
Ls1xj
I might have but I've been running a True Hi9 since I put in the LS1 and the 37 inch MTR's. The front Ultimate Dana 30 will also be for sale. I've never had a problem with it but I don't what to either.
LS1XJ
Old July 17th, 2009, 08:09 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Sell just the high pinion 3rd? And for someone looking is it 31 spline?
Old July 18th, 2009, 08:15 AM   #5
Ls1xj
Default ARB 31 spline Currie High Pinion 3rd member
Just what the add says. ARB 31 spline Currie High Pinion 9 inch 3rd member. I would like to sell it all together as a unit. Maybe if it doesn't sell after a while but I just listed it so would like to sell as is.
Old July 22nd, 2009, 12:23 AM   #6
wayne94gt
Default nice
been looking at these is this the best price any trades? will it work with all ratio's? thanks
wayne94gt is offline   Reply With Quote
Old July 26th, 2010, 06:31 PM   #7
gully369
PM sent
gully369 is offline   Reply With Quote
Old July 27th, 2010, 04:51 PM   #8
barh
Default currie
still have?
barh is offline   Reply With Quote
Old July 29th, 2010, 03:12 PM   #9
Ls1xj
Already sold.
Thanks. JOhn
Page generated in 0.45541 seconds with 51 queries
