92 f-250 questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 17th, 2009, 01:34 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default 92 f-250 questions
What axles would be under this truck and if d44 front would the splines on the axle shafts be the same as my 96 bronco. Would the Warn lock outs be compatable.
Also what would a 429 and matching trans (not sure what it is but they came out of the same car) that needs some rebuild work be worth. Alos has msd ignition, holly carb, newer headers.
The reason I ask is a buddy has a truck he is selling and I thought of buying for parts.
Silver Bullet is offline   Reply With Quote
Old July 17th, 2009, 01:42 PM   #2
Originally Posted by Silver Bullet View Post
What axles would be under this truck D50 and if d44 front would the splines on the axle shafts be the same as my 96 bronco if it was a 44 then yes. Would the Warn lock outs be compatable.
no D50 and D60 hubs are though
Old July 17th, 2009, 03:44 PM   #3
Silver Bullet
how difficult and would it be worth swapping to the d50 since I have 37's on the end of the d44
Old July 17th, 2009, 06:30 PM   #4
camccardell
tiger blood
camccardell's Avatar
PITA man
The arms are setup for leafs, not coils.
The inner shafs will work, but not the outer stubs.
I tried to do this and still have all the parts in my yard.
I have a TON of ttb parts, so If u are needin axleshafts, I'll sell ya as many as you want.
Chris
Old July 17th, 2009, 06:48 PM   #5
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
Originally Posted by camccardell View Post
PITA man
Chris
got any fullsize 87 bronco/f150 top hat hub stuff?
broncobuddha is offline   Reply With Quote
Old July 19th, 2009, 12:55 PM   #6
Never_Evil
The dana 50 axle found on Fords is a real bastard. It has ends and hubs similar to a dana 60, but has the pumpkin and shafts similar of a dana 44. I asked a question of if I could bolt in a dana 50 under my bronco and the general answer was no. The D50 twin traction beams are shorter on a d50 than a d44. The radius arms will also need some big fabrication.
The other answer that was popular was to swap in a solid axle either 44 or 60. Minimum fabrication and stronger in the over all.
Page generated in 0.22446 seconds with 41 queries
