Aluminum Rear Driveshaft 53" long from Center of U joints - $100 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2009, 01:01 PM   #1
HazardousRanger
HazardousRanger's Avatar
Send a message via AIM to HazardousRanger
Default Aluminum Rear Driveshaft 53" long from Center of U joints - $100
It is 53" from the center of one U-joint to the other U Joint. At the top of the driveshaft there is a slip yoke and at the bottom there is a flange that bolts to the rear axle. It will fit a Ford Ranger Extended cab which is what I bought it for and ended up not using it.
This thing is pretty much brand new itís just scratched from lying around.
I am located in Commerce, MI for pick up, but I will also ship if you cover the cost which I can get for you if you are interested. Thanks
HazardousRanger is offline   Reply With Quote
Tags
drive shaft, ranger
Page generated in 0.15691 seconds with 26 queries
