New problem 4l60e won't go into park - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 16th, 2009, 12:08 AM   #1
hondadirtracer
Skymaster
hondadirtracer's Avatar
Default New problem 4l60e won't go into park
I have a 1993 Chevy 1500 with a 4.3 and 4l60e trans. When i first got the truck it went into park, reverse, neutral, and drive fine. I then had to put it into first, and then the problems started. When you would shift it into gear, the gear selector on the dash did not match the gear you were in. It was like that for a few weeks. Then when I would shift from park to drive it would skip reverse and neutral and i would have to go into regular drive on the dash before it would shift into overdrive in the trans. Now, it will not go into park period, even when the dash is in park, the trans is in reverse. It is almost impossible to find neutral, and moving the shifter all the way down and all the way up fast and slow does not solve the problem. When you do find reverse or drive, it shifts fine and everything. I am not sure if it is the transmission or shift linkage or what. According to the po, he put in a gm re manufactured trans with 30k on it, and I have only put about 1500 miles on it. If you have any idea what the problem could be please help.
hondadirtracer is offline   Reply With Quote
Old July 16th, 2009, 03:58 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
sounds like a problem with linkage between shifter and trans. and also the small cable that goes to the indicator could be bound up.
Old July 17th, 2009, 12:39 AM   #3
hondadirtracer
Skymaster
How would i go about fixing the linkage if that was the case, i will check the cable in the morning.
Old July 17th, 2009, 10:27 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
is the linkage mechanical lever or does it have a cable from shifter to trans?
Old July 17th, 2009, 10:34 AM   #5
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
i think 93 still used to bar linkage, and your gear indicator just came loose from the steering wheel. there should be a plastic cover on the steering column just behind the dash trim piece, that has a string attached to it, mount that plastic cover back on the steering column and your indicator should work (or you could just count the clicks when you shift, worked for me for 3 months)
for your shift linkage to the trans (if it's not cable), make sure the bar goes through both holes in the bracket attached to the trans, sometimes the bar can shimmy out of one of the holes
Old July 17th, 2009, 10:40 AM   #6
awd6000ste
ABA
awd6000ste's Avatar
there is a rod that connects at the tranny gear selector under the truck with a coupling and a bolt to tighten it to the selector rod. over time the bolt can loosen and slide on the rod causing it not to be in the right position in relation to the indicator.
ive has this issue with a 91 blazer and a 93 blazer, both with the same 700r4/4l60e trans. youll need a buddy to sit in the truck while you adjust the linkage below to match what his lever is on.
what i did was completely disconnect the linkage, rotate the selector right on the side of the trans and get familiar with where the gears are. have your buddy put the lever in park, shift the trans manually buy hand into park, and tighten the bolt. run through the gears a few times to make sure its all lined up right.
its hard to explain in words but its really a super easy fix. crawl under there, find the selector/rod and youll understand what im talking about. id help ya but im two hours away and its a 5-10 minute fix. good luck!
awd6000ste is offline   Reply With Quote
Old July 17th, 2009, 06:20 PM   #7
hondadirtracer
Skymaster
Now i believe i have an even bigger problem. I disconnected the linkage and was moving it into different places, but it still would not shift into all gears no matter what position the gear selector was in. I unscrewed the nut that held a bracket onto the little rod that comes out the side of the trans. I was moving it through the gears and then it wouldn't go into any gears. I can move the rod that comes out of the trans in either direction for multiple turns and all it does is spin. Sometimes it will get a little stiff, but It will not go into any gear and i do not know what gear it is in.
Old July 18th, 2009, 10:39 AM   #8
hondadirtracer
Skymaster
anyone have a clue what is wrong? Am I going to have to take it to tranny tom or a transmission shop?
Old July 18th, 2009, 10:58 AM   #9
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
sounds like the linkage inside the trans has fallen off. i can fix it for you. send me pm if interested
Old July 21st, 2009, 10:25 PM   #10
hondadirtracer
Skymaster
kodiak fixed it for me.
Page generated in 0.36397 seconds with 53 queries
