Question about F250 axle compatability - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 14th, 2009, 05:08 PM   #1
Marine_mike
SNSHTF
Marine_mike's Avatar
Default Question about F250 axle compatability
OK. My stepdad's neighbor,s rear axle locked up on him. He has a 99 F250 diesel with a SRW axle. I was also told that the pumpkin had what he described as "rust holes" in it. Dunno about that. I have access to an 84 f250 SRW Dana 60. Will the 84 Dana 60 work with the 99? Thanks.
Click this link ---> http://www.gunwatcher.com/c/5751 is having a HUGE giveaway at the end of December 2014!
Marine_mike is offline   Reply With Quote
Old July 14th, 2009, 07:07 PM   #2
MilwaukeeF350
Dan
possible but he can't use his rim on your axle due metric lug pattern
and that F250 have 10.50 sterling.
Old July 14th, 2009, 08:17 PM   #3
DarrinGT
DarrinGT's Avatar
It wont be compatable with the Super Duty, The spring perches are different, and the dually rear end is wider than the SRW. But the main reason that you don't want to do the swap is because the Super Duty has rear Disk Brakes, and the 84 rear end has drum brakes.
For the rear end cover, they do tend to rust out and start leaking fluid, One real nice upgrade is to install a factory finned aluminum off of an 08 Super Duty. They are only about $50.00 right from Ford.
Good Luck!
DarrinGT is offline   Reply With Quote
Old July 14th, 2009, 10:03 PM   #4
Never_Evil
An older axle will not work because it will not have the VSS (vehicle speed sensor) in it. The VSS tells the computer how fast you are going and displays it on your speedo, and tells your transmission when to shift, if its an automatic.
Old July 15th, 2009, 12:17 PM   #5
DarrinGT
DarrinGT's Avatar
I found this on Craigslist today:
http://grandrapids.craigslist.org/pts/1271199507.html
AXLES, AXLES, AXLES, CHEAP, CHEAP, CHEAP (IMLAY CITY, MI)
Reply to: sale-mx3hc-1271199507@craigslist.org [Errors when replying to ads?]
Date: 2009-07-15, 12:07PM EDT
I have dozens of rear axles mostly for pickups, a few vans, Broncos etc. Call me or e-mail me with your needs. I sell Texas rust free truck parts for General Motors, Ford, Dodge & Jeep, so call us at 810-724-2357 or e-mail with your requests. Check out our inventory at www.southern-truck.com Some of our stock includes:
Ford Axles
1998, rear axle, 308 gear with drum brakes, 62000 miles, fits 97 - 99
1986, 3/4 ton, 8 lug, 353 gear ratio, open differential
1970, 9 inch, 28 spline, 273 gear ratio, open differential
1999, F150 rear axle in good condition, disc brakes, 355 gear ratio with speed sensor, tag #S829A. Axle has 2 new axle shafts and wheel bearings.
1997, F150 rear axle assembly with speed sensors, 3.08 gear ratio, drum brakes.
1999 Ford Superduty rear axle, 3.73 gear ratio, disc brakes, speed sensor is no good.
1999 Ford Superduty front axle, 3.73 gear ratio, disc brakes.
Old July 15th, 2009, 12:27 PM   #6
Marine_mike
SNSHTF
Thanks allot darrin.
Old July 15th, 2009, 07:42 PM   #7
Marine_mike
SNSHTF
OK... turns out the F250 that needs a new rear axle is actually a 94 diesel..... so I repeat the question with the correct year truck.
My stepdad's neighbor's rear axle locked up on him. He has a 94 F250 diesel with a SRW axle. I was also told that the pumpkin had what he described as "rust holes" in it. Dunno about that. I have access to an 84 f250 SRW Dana 60. Will the 84 Dana 60 work with the 94? Thanks.
Old July 15th, 2009, 08:23 PM   #8
DarrinGT
DarrinGT's Avatar
Is the 94 an automatic or a stick?
Like MR Evil stated the 94 has a speed sensor in the rear end, and the 84 does not. If it is an auto, the trans relys on that signal to work correctly. If it is a stick, it will only mess the rear antilocs.
What gear ratio to you need?
Old July 15th, 2009, 08:25 PM   #9
MilwaukeeF350
Dan
i have that rear axle
it came from 93 F350.
Old July 15th, 2009, 08:27 PM   #10
Marine_mike
SNSHTF
How much milwaukee?
Old July 15th, 2009, 08:27 PM   #11
MilwaukeeF350
Dan
is $200 good?
Old July 15th, 2009, 08:28 PM   #12
Marine_mike
SNSHTF
Wasn't sure if it made a difference when I found out it was a 94 vs a 99 as initially thought
Old July 15th, 2009, 08:28 PM   #13
Marine_mike
SNSHTF
let me get back to ya... it from a 94 diesel srw?
Old July 15th, 2009, 08:34 PM   #14
MilwaukeeF350
Dan
no
but they use same rear axle
Ford 10.25
pic of 10.25 from internet it look like this http://detroit.craigslist.org/pts/1262877131.html
gear ratio is 3.55
Old July 15th, 2009, 08:36 PM   #15
MilwaukeeF350
Dan
F250 and F350 use sterling 10.25
I am sure F250 HD with diesel should be sterling 10.25
do you see this diff cover with plug or no plug on it?
Old July 16th, 2009, 12:26 PM   #16
Marine_mike
SNSHTF
Can't really see anything from here... I'm in mosoul, Iraq. I'll ask my stepfather to take a look at the diff cover for me though.
Old July 16th, 2009, 12:52 PM   #17
MilwaukeeF350
Dan
Thank for support American congratulate on you.
Can he look at cab's sticker like Vin? look at axle code so I can know what gear ratio he have. question do he have 4X4 or 2wd?
Old July 16th, 2009, 01:17 PM   #18
Marine_mike
SNSHTF
I know it's 2WD..and I'm waiting on a response to the other questions.
Old July 18th, 2009, 11:54 AM   #19
insaneoffroader
insaneoffroader's Avatar
Originally Posted by DarrinGT View Post
One real nice upgrade is to install a factory finned aluminum off of an 08 Super Duty. They are only about $50.00 right from Ford.Good Luck!
you don't have the ford part # by chance
insaneoffroader is offline   Reply With Quote
Old July 19th, 2009, 09:10 AM   #20
Broncoholic
Guest
Posts: n/a
I have a 08 SD F350 Axle from a srw V10. Nice upgrade for ya, Like new would work for ya:
http://www.greatlakes4x4.com/showthread.php?t=139195
Page generated in 0.48463 seconds with 83 queries
