chevy 350 questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 11th, 2009, 08:10 AM   #1
ladiekilla04
ladiekilla04's Avatar
Send a message via AIM to ladiekilla04
Default chevy 350 questions
how do i figure out what generation chevy 350 block i have, it's out of a 97, but i dont know what it's out of. also, does roller mean it has the lifters with rollers or does it mean something else, and if so can i use flat lifters or do i need the roller ones. thanks
ladiekilla04 is offline   Reply With Quote
Old July 11th, 2009, 08:41 AM   #2
TanTahoe
TanTahoe's Avatar
Roller blocks mean it can except roller lifters with out too much effort. If it is a gen I block then, Yes you can run flat lifters but you have to change your cam to flat lifter cam as well.
If it is out of a truck/van it will be a gen I block. If it came from a caramo/firebird/corvette I believe its a LS1 or LT1, I forget if 97 or 98 was the change in motors. I dont delive you can run a flaty cam in one of these motors.
If the water pump is off, look at the water jacket holes. if it only has one hole pre side, it should be a gen I block.
TanTahoe is offline   Reply With Quote
Old July 11th, 2009, 10:03 AM   #3
ladiekilla04
heres a picture of the front of the block. the red arrows are bolts for a piece that wasnt on the 94 engine i just tore apart and i was wondering it it or the other pieces i noticed were different could help identify the engine
Old July 11th, 2009, 10:43 AM   #4
TanTahoe
TanTahoe's Avatar
All of those peices are for a roller cam setup. Its a gen I block. Id keep it roller unless you already have a flat tappet cam.
These bolts hold your cam retainer plate in place. Stops the cam from "walking" front to back.
These slid over the top of the lifters to they dont rotate in there bore.
And this "spider" bolts inside your lifter valley to put tentsion on the picter above and keep them from moving
Old July 11th, 2009, 11:11 AM   #5
ladiekilla04
thank you very much
Old July 11th, 2009, 11:23 AM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
all production 350 1987 and up blocks are roller cam compatible if the last 3 of the casting number are 638 or 880.
Old July 11th, 2009, 03:43 PM   #7
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
the plate that hold the cam in is called a thrust plate. the only reason GM put them in was because of the Iroc Z. they were running into problems when the cars would slow down fast. come to find out without the friction of the lifter the cam would slide out the bores until it contacted the timing cover. at this point it went forward far enough it would retard the distributor advance to the point it would stall. I replaced several that were "Missed" in production
Yetti
Old July 11th, 2009, 04:45 PM   #8
ladiekilla04
thanks for the good info, i wish some of you guys were down here it's hard to find knowelgeable help down here
Page generated in 0.27502 seconds with 47 queries
