Redemption - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2009, 07:23 AM   #41
KartRacer
Blowd up
KartRacer's Avatar
Looks good Nuzzy.
+2 needs more windshield bar.
Old August 31st, 2009, 11:42 PM   #42
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
updates?
nixxerRsixxer is offline   Reply With Quote
Old September 1st, 2009, 11:41 AM   #43
roll-bar Bob
roll-bar Bob's Avatar
It looks like a much safer setup
Old September 1st, 2009, 12:44 PM   #44
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Used my awesome welding skillz to burn on all my harness tab mounts.
So now we can finally be "safe"
Nixxer mocking up the sexy looking antiwrap bar
Daryl made short work of drawing up a skid to cut out on the plasma table. One quick bend and she was ready. (I'll add some hidden angle iron reinforcements later)
Drilling and taping 14 holes in the frame is a blast...
Then on to fixing my broken tranny mount. I wanted to do something off my clocking ring to take advantage of more attachment points but was stuck on how to proceed. Nixxer saw me staring confused, hating life and hatched a plan.
Was made harder by the fact that my clocking ring was permanently attached to the case via locktite. Thus, he cut the mount slightly bigger than the ring so he could get full penetration from just the one side, while not adding any material past the flat mounting surface. Dude's got talent
Just a bit of finish welding and maybe boxing in where the drop out crossmember attaches to the old mounts. But I'm fully stoked how it came out!
Nuzzy is offline   Reply With Quote
Old September 1st, 2009, 12:46 PM   #45
KartRacer
Blowd up
KartRacer's Avatar
Not bad for some white boys.
Old September 1st, 2009, 12:57 PM   #46
xj4life
xj4life's Avatar
Nice
Old September 1st, 2009, 01:06 PM   #47
Nice work guys
Old September 2nd, 2009, 09:36 PM   #48
nixxerRsixxer
Homewrecker
looks like shit!
Old September 13th, 2009, 02:28 AM   #49
Nuzzy
Nuzzy's Avatar
Wanted to get the jeep out of the shop and back home, so Friday after work I set in for the night. Was just me, so unfortunately there was no
"pretty" fab accomplished. Just good ol' Nuzzy style redneckery
Started off finishing my frame tie-ins for the cage in the front. No pics, but just took 2"ish long sections of tube from the floor plate and extend to my slider legs.
Then I took my new cross member out to finish the welds. While putting it back in, I got into a fight... It was being a pain to line up and on top of that, I hated the access to the bolts (from using the preexisting mounts, the bolts were so close to the tube that a socket wouldn't fit). As has been my rule from day one with this shitbox, anything hard to access gets changed/moved or it's surrounding area cut out so I don't have to wrestle with stuff. Thus, out came the plasma and off came the old mounts.
New mounts welded to frame, bolts have more than enough room to fit an impact, and I left enough space to easily line things up, relying on the bolts/nuts to pull everything in snug.
Then turned up the juice and burned on D ring tabs (2 front, 2 back) since until this point I had no real recovery points. (Yes the shackles are like that because the rig is in the hoist)
I sat thinking about my anti-wrap bar for a bit. Goal was to use parts I already had, and that included a heim with weld in bung as a shackle. I wanted to mount in double shear, but my pressing desire to finish the damn thing quickly took over. So scrounging through the scrap, I found stuff I thought I could make work. A piece of old steering stock drilled out to 5/8ths ID with a nut welded on the end and a piece of thicker wall tube drilled through so I could add plug welds seemed to do the trick for the time being.
It's a little crooked in spots, but I think that goes for everything on my rig I did originally want more separation on the axle end, but for ease I just ended up using some brackets I had from A&A Fab and that's what I got for holes.
After remounting my skid, cleaning up the tools, taking the wood sides off my trailer, and loading the jeep, it was 4am. After 19 hours in the shop, an MGD dinner and dessert, and no less than 8 Codeine filled Canadian issue pain killers (my back is pissed at me), I was finally bringing my baby home. I was simply overjoyed.
Prolly take it off the trailer and start painting the cage tomorrow.
Old September 13th, 2009, 04:26 PM   #50
nixxerRsixxer
Homewrecker
lets see that painted cage nuzzy!
btw did you keep the JCR futbol on the back? .. might want to make sure its centered i just had it tacked on too..
Old September 13th, 2009, 09:19 PM   #51
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
lookin good!!! lets see some more pics of the finished product
lososjoyride00 is offline   Reply With Quote
Old September 13th, 2009, 11:59 PM   #52
Nuzzy
Nuzzy's Avatar
Nope. Was in the field of view
Might stick it somewhere else though
Old September 14th, 2009, 01:24 AM   #53
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Originally Posted by Nuzzy View Post
it was 4am.
Welcome to the JCR 4am club. My consecutive hour record is probably unbeatable though.
JcrOffroad
Zoom Zoom!
Old September 14th, 2009, 01:41 PM   #54
Nuzzy
Nuzzy's Avatar
I do seem to remember coming in at 9am and finding you still working from the night before, shortly before South Dakota
Old September 15th, 2009, 08:08 PM   #55
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
looking good fuzzy nuzzy.
Old September 15th, 2009, 09:46 PM   #56
Nuzzy
Nuzzy's Avatar
Cage is painted. I found myself wondering how many spray cans the air in my garage can hold... And have also decided I should not operate heavy machinery tonight
Seriously, my boogers have boogers that are freakishly black.
Old September 15th, 2009, 11:43 PM   #57
Nuzzy
Nuzzy's Avatar
So, so much paint inhaled tonight...
Old September 16th, 2009, 12:02 AM   #58
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
looks fly
nate4d is offline   Reply With Quote
Old September 16th, 2009, 08:55 AM   #59
Nice
Page generated in 1.20560 seconds with 80 queries
