99 explorer tha i wanna lift.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2009, 03:59 PM   #1
JeepGirl88
JeepGirl88's Avatar
Default 99 explorer tha i wanna lift..
what is some cheap ways to lift this for some 33's? i am looking at cheap ways to do this and wanna fit some 33/12.5 on it
JeepGirl88 is offline   Reply With Quote
Old July 10th, 2009, 04:13 PM   #2
badazzamc
Get Some
badazzamc's Avatar
I think cheap is out of the question.
Old July 10th, 2009, 04:20 PM   #3
JeepGirl88
JeepGirl88's Avatar
well what can i do? i know u can do a body lift to them but i hate body lifts
Old July 10th, 2009, 07:06 PM   #4
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
body lift is the only cheap thing you can do. superlift makes a kit but there around 1600 bucks and you will also need a new front driveshaft for another 400.
if i had 2K to drop i would put a solid front axle under it
Old July 10th, 2009, 07:51 PM   #5
JeepGirl88
JeepGirl88's Avatar
how much lift does that give u??
Old July 10th, 2009, 08:03 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
just throwing an axle under it doesn't give you lift.
Old July 10th, 2009, 08:11 PM   #7
JeepGirl88
JeepGirl88's Avatar
no the lift superlift makes
Old July 10th, 2009, 08:28 PM   #8
sanman
sanman's Avatar
bushwhacker flair's= 33's
sanman is offline   Reply With Quote
Old July 10th, 2009, 09:28 PM   #9
JeepGirl88
JeepGirl88's Avatar
yea i know its stock with 245's which are 31's.. so yea im sure it would fit 33's with some trimming but triing to keep it looking decent family wheeler
Old July 10th, 2009, 10:16 PM   #10
traveller
traveller's Avatar
Any size tire you want will fit cheapest lift on the market
traveller is offline   Reply With Quote
Old July 16th, 2009, 02:19 PM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
sell a dog first?
@clarkstoncracker
Old July 16th, 2009, 03:42 PM   #12
Yota Bill
not sure if this helps much, but I put 285/75-16's (32.8 diam) on a stock 99 Ranger sport, and the only rubbing that has ever occured is just barely on the front sway bar, which I can only tell that by the paint rubbing off of the sway bar, never felt it touch at all...maybe there are some parts that can be swapped from the Ranger to get them to fit, not sure, but something to look into
Old July 16th, 2009, 04:13 PM   #13
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
buy my entire superlift lift kit in december. has about 10k on it
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old July 16th, 2009, 07:52 PM   #14
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
33's might take a little work, but I suggest this:
2-3" body lift.
Extended shackles (rear)
T-bar crank up front (I think those years have t-bars sill?)
This will be roughly 4" lift over stock, but because of the fender shape, you might still get a bit of rubbing. You might have slightly better luck with a 33x10.5 too.
Old August 16th, 2009, 09:39 PM   #15
Heavymentill
Heavymentill's Avatar
I'm running 33x12.5 on my 96 Explorer with torsion bars cranked, warrior 153 shackles, and a 3" Performance accesories body lift. Also a minor amount or trimming. Its about 5 1/2" to 6" of lift.
Heavymentill is offline   Reply With Quote
Old September 3rd, 2009, 03:48 PM   #16
radhazard1
radhazard1's Avatar
Send a message via MSN to radhazard1 Send a message via Yahoo to radhazard1
Thumbs up
Look at my 97 Explorer. Cheap ass lift. Crank the torsion bars, Have the rear leafs done to make it match, 2 inch body lift. The rear doors are way too close to the fenders which is why they don't make a flare kit for it, at least not 3 years ago when I did mine. I fit 33" BFG and Claws with no problem on 15x8 rims. I also had to make upper control arms though to get the camber/caster right. Total cost was around $200.00. But I would LOVE the superlift kit which is a 4" lift.
radhazard1 is offline   Reply With Quote
Old September 4th, 2009, 06:34 AM   #17
fsumotorhead
N8KVB
fsumotorhead's Avatar
i would say put your money into an aussie locker for the rear and 31s. you will go farther than opens and 33s, and 31s are easier to fit.
Old September 4th, 2009, 10:00 AM   #18
radhazard1
radhazard1's Avatar
Thumbs up
The rear may already have a very good limited slip. I replaced mine last year and it made a huge difference. Obviously my original one wasn't working worth a poop. I am not happy with 33's and 4:56 gears so I understand 31's sucking also. There is A LOT to drag under these body styles and the suspension sucks when it comes to articulation. I have the locker, gears, power, and 33's but a lot of the time I have to gun it up and over things if there are a lot of holes here and there. But it makes it! I am hoping for the 4" lift and then some 35's in the future.
Page generated in 0.39768 seconds with 77 queries
