I need someone with a portable welder - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2009, 01:02 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Exclamation I need someone with a portable welder
Some how it appears I have either cracked or put a hole im my rear axle at the passanger sring perch. I am leaking fluid from the perch area.
Has anyone ever had this happen to them? Or anyone have any advice. i was thinking if the perch put a hole in the tube or a weld broke causing the leak re welding around the perch should fix it. If not its worth a shot.
I will remove the tire, spring pack and clean up the perch to weld around.
Does anyone have a portable welder that could swing by?
Silver Bullet is offline   Reply With Quote
Old July 9th, 2009, 01:12 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
can you weld at all? i have a small mig that would do the trick but i'm not by any means a professional welder.
Old July 9th, 2009, 01:16 PM   #3
Silver Bullet
never welded in my life.
Old July 9th, 2009, 01:26 PM   #4
Silver Bullet
actually I have a buddy that can weld. Would a mig weld that ok?
Old July 9th, 2009, 01:31 PM   #5
Broncoholic
Guest
Posts: n/a
Of course a MIG would work. Call Randy 248-360-1122 Allied Welding
Old July 9th, 2009, 01:37 PM   #6
95geo
newbie
95geo's Avatar
mig is good, try to keep the wind away from it or use flux core wire. If you want to drive up here I could do it but it's a long drive...
Old July 9th, 2009, 03:12 PM   #7
Silver Bullet
i am hoping to get portable so I can break it down in my driveway.
What is an arc welder use for.
Old July 9th, 2009, 03:13 PM   #8
Axe Lip
Go Lions
Axe Lip's Avatar
thats funny how do you know randy? he's a good guy
Axe Lip is offline   Reply With Quote
Old July 9th, 2009, 03:21 PM   #9
Broncoholic
Guest
Posts: n/a
I feed his Alligators
Old July 9th, 2009, 03:22 PM   #10
Broncoholic
Guest
Posts: n/a
If you get it broken down bring it to Union lake & we will do it up for ya... PM if coming tonight.
Old July 9th, 2009, 03:30 PM   #11
xjmichigan
xjmichigan's Avatar
I can drop mine off. Do you have an available 220v outlet and/or a 30+amp 110V within 50'?
Old July 9th, 2009, 03:57 PM   #12
Silver Bullet
nope what if i brought it to your house and tore it down.
Old July 9th, 2009, 08:11 PM   #13
Broncoholic
Guest
Posts: n/a
That would work too, I will break out the Plasma cutter
Old July 9th, 2009, 10:31 PM   #14
firehawk
Live Action!
firehawk's Avatar
Originally Posted by Broncoholic View Post
That would work too
Why am I getting the feelin Broncoholic is Billy Mays reincarnated?
Old July 10th, 2009, 08:39 AM   #15
Broncoholic
Guest
Posts: n/a
I am just such a great guy.
Page generated in 0.24189 seconds with 68 queries
