long arms - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2009, 12:21 AM   #1
jeepguy74
jeepguy74's Avatar
Default long arms
what is the best stock to build them out of??? other than solid??
Old July 7th, 2009, 07:56 AM   #2
jeepnxj96
jeepnxj96's Avatar
I use 2"x1/4"wall DOM and make weld in threaded bungs for the end
Old July 7th, 2009, 09:49 AM   #3
CreativeFab
used to be Ironman
CreativeFab's Avatar
.25 wall minimum if using mild steel tubing
Old July 10th, 2009, 08:07 AM   #4
xj4life
xj4life's Avatar
x2
Old July 10th, 2009, 08:47 AM   #5
jeepguy74
jeepguy74's Avatar
what ya make the bungs out of?
Old July 10th, 2009, 09:08 AM   #6
95geo
newbie
95geo's Avatar
1.75x.25" minumum, 2.0x.25" is common, 1.75x.188" heat treated chromoly is the new hotness, solid 2.0" 7075 aluminum is up there but not as "flexible" to work with/weld to, 1.75" 7075 is the minumum for lowers. you can fabricate links out of .125" .188 or .25" wall materials if you want, it just takes some careful fixturing.
solid is stupid, the inner 75% of the material does virtually nothing for strength, hollow is the strongest/weight and nobody uses hollow aluminum because it will dent and lose all of it's strength.
These are the baddest links on the market right now: http://www.spidertrax.com/products/Chromoly-Links
Old August 17th, 2009, 11:40 AM   #7
jeepnxj96
jeepnxj96's Avatar
usually just hot rolled that I turn on my cnc and thread, but if some one wants I can make them out of 4140 or anything really.
http://rickybuilt.webs.com/builderparts.htm
Page generated in 0.23495 seconds with 44 queries
