Transfer Case rebuild - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2009, 04:21 PM   #1
monster toy
Northwest Ohio Crawlers
monster toy's Avatar
Default Transfer Case rebuild
Does anyone have a transfer rebuild kit or know how to fix a transfer case that gets stuck in neutral when shifting from 4 wheel low to 2 wheel drive? I have a 1987 Suzuki Samurai.
monster toy is offline   Reply With Quote
Old July 6th, 2009, 04:34 PM   #2
scottie
Eye candy
scottie's Avatar
It may not need a rebuild, but just the shifter sheet replaced.
Some places that will have rebuild kits and shift sheets
www.trailtough.com
www.hawksuzukiparts.com
Old July 7th, 2009, 08:11 AM   #3
A4X4SPIT
A4X4SPIT's Avatar
scottie is right try replacing the shifter sheet 1stIve had that issue several times & the shifter sheet fixed it
A4X4SPIT is offline   Reply With Quote
Old July 7th, 2009, 05:15 PM   #4
monster toy
Where is this shifter sheet and how hard is it to replace? That would be great if that all it is!!
Old July 7th, 2009, 05:55 PM   #5
scottie
Eye candy
scottie's Avatar
Well not to be an ass, but its on the shifter of the T-case
It's the little cup part the ball of the T-case shifter rides on, not sure how bad it is to replace if never had to do it, you may have to take the t-case out, so it might take you 40 mins.
Unscrew the shift knob, remove the 4 screws that hold the boot on, slide the boot off, Then take another boot off, then take the shifter out by pressing and turning the little cage doodad, and look down the hole
Old July 7th, 2009, 09:32 PM   #6
monster toy
Thanks for the help. I have one on order. Let you know if it works!!
Old July 8th, 2009, 09:40 AM   #7
A4X4SPIT
A4X4SPIT's Avatar
hey its not hard to do in the sami the worst part is reaching down to put shifter back in
Old July 26th, 2009, 08:16 PM   #8
samuraijunkie
Remeber this?
samuraijunkie's Avatar
x2 not hard at all to replace 10 min job total or if you measure in beer about 1 1/2-2 beer job.
samuraijunkie is offline   Reply With Quote
Page generated in 0.41565 seconds with 47 queries
