desperate need of help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 5th, 2009, 05:43 PM   #1
Mookie
Mookie's Avatar
Location: Dearborn(home of hommous, Fattoush, tabbouli), Wayne County, Michigan
Send a message via AIM to Mookie Send a message via MSN to Mookie Send a message via Yahoo to Mookie
Default desperate need of help
I have a 97 2.5 tj that i just swapped in. Im pretty sure that i have everything connected properly. when i turn the key, all i get is a click no starter turning, nothing trying to fire.
I honestly dont know where to start lookiing next. I put a wrench on the crank and tried turning it but got nothing. would that cause the starter to not move?
Mookie is offline   Reply With Quote
Old July 5th, 2009, 05:45 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
check all your grounds first
Old July 5th, 2009, 05:51 PM   #3
Mookie
Mookie's Avatar
im going over that again right now.
I know this is the stupid thing to do, but when i cross connections on the starter it should try to turn over right? while i was tryingt o put it on, i kept hitting one of the wires to ground constantly and shorting shit out. now i cant to it to save my life so ill look there.
Old July 5th, 2009, 05:51 PM   #4
sanman
sanman's Avatar
you put a wrench on the crank bolt and you can't roll the motor over by hand?
sanman is offline   Reply With Quote
Old July 5th, 2009, 05:53 PM   #5
Mookie
Mookie's Avatar
yeah thats exactly what im saying. and i can get the starter to try but nothing is turning over.
Old July 5th, 2009, 05:55 PM   #6
sanman
sanman's Avatar
had you heard the motor run before you put it in
Old July 5th, 2009, 05:56 PM   #7
Mookie
Mookie's Avatar
thats a big no on the hearing the engine.
Old July 5th, 2009, 05:59 PM   #8
sanman
sanman's Avatar
you should be able to turn the motor over by hand. put a breaker bar on it and try and get it to roll over. if you can't my .02 is the motor is froze up.
Old July 5th, 2009, 06:03 PM   #9
sanman
sanman's Avatar
stick or auto?
Old July 5th, 2009, 06:17 PM   #10
Mookie
Mookie's Avatar
could it just be "stuck" I believe the engine has sat for quite a while. Im putting a breaker bar on it but the onlything turning is the bolt still and i dont want to bust it off. excuse im idoiocy but if i push the jeep and throw it in gear will it try to turn it over?
Old July 5th, 2009, 06:21 PM   #11
HVYRTFT
Reed my teef
HVYRTFT's Avatar
I believe that's what sanman was getting at. And yes, if it is a manual, you should be able to get it rolling, dump the clutch and vroooom.
Old July 5th, 2009, 06:32 PM   #12
mokerlund17
mokerlund17's Avatar
Send a message via AIM to mokerlund17
exactly how long is quite a while and was there any oil in it
mokerlund17 is offline   Reply With Quote
Old July 5th, 2009, 06:38 PM   #13
Renegade II
Coil springs are for pens
Renegade II's Avatar
Yup, dump the clutch and vroooom all your compression rings are broken and maybe crack a piston
If it doesn't roll backward or forward it probably is froze up. Squirt fuel oil in the plug holes, let it set for a day and try again.
Page generated in 0.23941 seconds with 62 queries
