Prop problem?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 5th, 2009, 02:47 AM   #1
94transam25th
94transam25th's Avatar
Default Prop problem??
Ok so i am new to owning a boat, my dad has had boats all my life but i just bought my first boat last week and had it out today and doesnt seem right i think its a prop problem
here it goes.
on the boat when i got it it had a 19pitch prop and those little dolphins on the outdrive... it takes quite awhile to plane and seems like it will run way too high of rpm. if i let it go wide open throttle it would go all the way to 5500 or maybe even above just didnt want to try and only doing 32 mph gps... also i pretty much had to keep the trim all the way down otherwise the rpm would get too high
my dad gave me a 23p mirage stainless steel prop do you think i will even be able to plane with this since i had trouble planing a 19p?
the boat is an 86 cobalt with 5.7v8 260 and alpha one seems to me it should do faster than 32
any suggestions?
94transam25th is offline   Reply With Quote
Old July 5th, 2009, 08:57 AM   #2
JeepRat
Infidel
JeepRat's Avatar
Read through this Michigan Wheel Catalog. It will give you an idea of where you should be with a prop. It may still take testing a couple to get you in the right RPM range.
http://www.miwheel.com/FilesCustom/HTMLEditor/Files/MWC%20-%20OBSD%2009.pdf
Something else you can look into is Smart Tabs http://www.nauticusinc.com/
JeepRat is offline   Reply With Quote
Old July 5th, 2009, 10:14 AM   #3
firehawk
Live Action!
firehawk's Avatar
What pitch prop came with it?
Old July 5th, 2009, 11:26 AM   #4
94transam25th
it came with a 19pitch but if i would let it rev out it would go all the way to 6k rpm i bet
and only hitting 32 mph with this setup seems way to slow
Old July 5th, 2009, 09:45 PM   #5
firehawk
Live Action!
firehawk's Avatar
Sounds like the prop your dad have you is a step in the right direction unless there is a problem elsewhere.
Post up the results.
Old July 6th, 2009, 12:02 AM   #6
94transam25th
i put the 23 pitch on and am a lot happier with that than the 19p... i had 9 people and a full tank of gas and gps'ed at 40 in pretty rough water so about a lil more than 4k rpm im thinking if i can find a good 21p i will be good because the 23 took awhile to plane
Old July 6th, 2009, 06:51 AM   #7
greygoose
I'm the dude
greygoose's Avatar
Yeah, 23p is a little much for a small block. 21p sounds like it would work well for you. You forgot to mention prop size though, because different diameters make a difference in plane time and rpms as well.
Old July 7th, 2009, 05:05 PM   #8
94transam25th
im pretty sure all 3 props i have are 14 inch
Page generated in 0.21445 seconds with 47 queries
