1995 Mustang GT - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 4th, 2009, 06:21 PM   #1
transamsam
lucky #13
transamsam's Avatar
Default 1995 Mustang GT
For sale is a 1995 Mustang GT. It has 150,000 mles on the body and 40,000 on the engine I replaced the gauge cluster with another one so there is only 44,000 on the cluster itself.. It is a 5.0L with some aftermarket parts. It is green in color and is a 5 speed car. Here is a list of the aftermarket that is on the car.
Aftermarket:
Trick flow upper and lower track heat intake
BBK underdrive pulleys
BBK fuel pressure regulator
BBK long tube headers
Flowmaster mufflers
MSD distributor cap and rotor
A/C delete
Smog Pump delete
Adjustable clutch cable
BBK lowering springs
Ford E 303 camshaft
Aftermarket headlights
Cobra hood
BBK cold air intake
Summit racing Throttle body 75mm
Trick flow 75mm elbow
Summit racing 75mm mass air flow sensor that is tuned to 19lb injectors
Spark plug wire sleeves on the boots to help with melting from the headers
Moroso Spark plug wire seperators
MSD coil
Extra Parts
Upper and Lower Shift boot (brand new)
Camber and Caster Plates (brand new)
Stock 8.8 Rear end gears 2.73
Stock Chrome tail pipes fom a 1998 Mustang GT
Not so good things
Has some dents ( not bad)
Rear Bumper cover is cracked
Needs to be painted (does not look bad just would get re painted myself)
Clutch needs to be adjusted
Needs to be tuned ( because of the after market parts)
Needs new tires
Will have to be trailer home unless you want to try and drive it. Which is possible just have to keep the idle up so it wont die.
Does start and run. Runs very good. just when you start to drive it the idle will go up and down and then stall if you don't keep an eye on it. It will start and run fine and idle good untill it warms up then the idle will start to go up and down. Have been told by many people that the reason that it is acting like this is because it needs a tune because of all the aftermarket. Does not over heat, misfire, or back fire. It is a great running car like I said all it needs is a tune.
So that is what I have. Looking for 3,500 OBO or trade for a 97 and up jeep cherokee, or 4x4 SUV, truck, or Seadoo's 1 or 2 with a trailer.
transamsam is offline   Reply With Quote
Old July 4th, 2009, 06:48 PM   #2
methodx55
methodx55's Avatar
Send a message via AIM to methodx55
trade for a 1962 mud truck?
methodx55 is offline   Reply With Quote
Old July 4th, 2009, 07:09 PM   #3
transamsam
lucky #13
transamsam's Avatar
No thank you not really looking for a mud truck
Old July 4th, 2009, 09:48 PM   #4
Jeepunk95
trade for a 1997 gmc suburban 4x4 1500 with 224k miles on it?
Jeepunk95 is offline   Reply With Quote
Old July 4th, 2009, 09:58 PM   #5
transamsam
lucky #13
transamsam's Avatar
No thank you that a little to big for my taste.
Old July 4th, 2009, 11:46 PM   #6
methodx55
methodx55's Avatar
well its not really a mud truck, its a 1962 f-100 4x4 lifted 9inches with 35" bfg allterrains
Old July 5th, 2009, 08:57 AM   #7
transamsam
lucky #13
transamsam's Avatar
Yeah I am going to need something that is a little smaller. More of a DD is what I am looking for.
Page generated in 0.22308 seconds with 44 queries
