Head?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2009, 08:59 PM   #1
Immortal
NO RELIGION WAT!
Immortal's Avatar
Question Head??
If a valve spring is broken/wasted would the engine still start??
Old July 3rd, 2009, 09:03 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
should. 1 cylinder dead won't affect it enough to cause a no start. i wouldn't start it due to possibility of dropping a valve and destroying the engine. i replaced an engine in an impala that did just that and caused alot of carnage.
Old July 3rd, 2009, 10:17 PM   #3
jbsjunk
Little Member
jbsjunk's Avatar
If the spring is broken or loose enough to float, it could hit the piston but it should start.
Old July 4th, 2009, 02:02 AM   #4
firehawk
Live Action!
firehawk's Avatar
I replaced a broken valve spring on a 2000 Durango with the 360 in it last summer.
It did not run very well and sounded like shite!
Dont think it idled on its own. But did start, somewhat.
Old July 4th, 2009, 10:20 AM   #5
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
yes it will run. does it miss at all? easy to tell with cover off. or if you wanna be a nig run a compresson test and the cyl should be noticably different due to the spring being broke the valve wont fully seat.
Old July 6th, 2009, 03:56 PM   #6
PavementPounder
PavementPounder's Avatar
Is this on your YJ or your pimp limo?
Page generated in 0.19867 seconds with 41 queries
