"A" Post Off Road Lights - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2006, 03:22 PM   #1
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
Default "A" Post Off Road Lights
Does anyone have Off road lights mounted on an XJ? I have seen them before but never a good enough pic to tell how it was done. I was thinking of just making an "L" bracket with the bottom peice to match the angle of the post. Does anyone want to share a better idea?
FlamesFearMe is offline   Reply With Quote
Old June 29th, 2006, 08:07 PM   #2
Blackbeast2
Hardcore since 84
um try putting them on the bumper if you cant figure any thing out. Most come with everything needed/
Blackbeast2 is offline   Reply With Quote
Old June 29th, 2006, 08:51 PM   #3
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Cheapies don't come with a relay. You'll want to use one to wire your lights up.
Old June 29th, 2006, 09:32 PM   #4
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
the appropriate relays are usually located right next to where you got the cheapy lights.
scorpio_vette is offline   Reply With Quote
Old June 30th, 2006, 09:41 AM   #5
bigblocked
bigblocked's Avatar
Bluexj has them. Try looking at some of his photos or PM him.
bigblocked is offline   Reply With Quote
Old June 30th, 2006, 09:45 AM   #6
xj4life
xj4life's Avatar
i've seen them mounted directly on the stock bumper but i choose to mount mine on a simple aluminum bracket i made at home.
Old June 30th, 2006, 10:03 AM   #7
Never seen brackets to mount them to the A-pillar, myself.
I'd say you are going to need to fab them. Would look decent to drill through and run the wires tucked inside the A-pillar behind the interior trim.
i'd think a small piece of 1/8" thick flat, with the actual mount point coming off that. I'd try to use some type of thin gasket/rubber between the plate and the body when you bolt it in place.
Old June 30th, 2006, 03:24 PM   #8
FlamesFearMe
Custom User Title
Thanks. It wouldnt take much to make the bracket, so I will probably do that. And teh wiring would be nice all tucked into the interior trim. When I get them done I'll post some pics to hopefully help someone else out down the road.
Flames
Old June 30th, 2006, 03:39 PM   #9
broke
Never good enough...
broke's Avatar
I've seen a 00 black XJ on S-us 23 heading towards Ann Arbor. It looked sweet, Did you check naxja.org?
broke is offline   Reply With Quote
Old June 30th, 2006, 03:44 PM   #10
FlamesFearMe
Custom User Title
I can never get anyone to reply to anything on that site. I think maybe they don't like me.....
Old July 1st, 2006, 12:36 PM   #11
broke
broke's Avatar
yeah they hate if you do not search the item first. But there is a ton of great info on there, even though it might take a while to find. Good luck
Old July 13th, 2006, 09:35 AM   #12
Kawierider
Kawierider's Avatar
I just saw one the other day with A pillar lights from the factory.
Look around and see if you can find a set of the brackets that came with the police intercepter versions. They had them.
They are of course the kind of mounts that can be swiveled but thats easy to change.......
Old July 19th, 2006, 05:47 PM   #13
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Prolly end up with the same trouble SWB rigs have when they run hinge mounted lights...too much glare off the hood to be very useable.
x2 on the bumper mount.
Old July 19th, 2006, 10:14 PM   #14
Tonka
Tonka's Avatar
cb antenna mirror mounts can be used to mount them to the stock roof rack bars...
Old July 19th, 2006, 11:53 PM   #15
Pre4runner
Bike Dude
Pre4runner's Avatar
mine are mounted on my bike rack, ran wires up the door pillar and out between the doors with a disconnect so i can remove the rack easy, worked better then i thought, plus no glare. Great for my rally runs to caseville
Page generated in 0.27975 seconds with 68 queries
