RockCrusher Dana 60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 23rd, 2005, 11:02 PM   #1
Big Daddy Rubicon
There watching me! (.)(.)
Big Daddy Rubicon's Avatar
Thumbs up RockCrusher Dana 60
Just to give you guys a another axle to think about. I have just installed a RockCrusher rear high pinon Dana 60 in my rubicon. I'm running 37" tires and I was tried of breaking the rear axle. Yes I did upgrade to Supieror axleshafts in the Dana 44, still broke them. So after looking around I went with this one. I did have to do some fab work for a rear sway bar mountsand axle vent. This thing does weight a ton and from the guys that are running them, they had nother bad to say about them. Just a FYI for those that are looking for axles.
[QUOTE=a.j. hall;1528363]
[/QUOTE]
Old November 23rd, 2005, 11:39 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
I think i'd rather go with a corp 14 bolt... you can change an axle shaft in minuites.. Dana 60 isn't full Floating is it ?
Old November 24th, 2005, 06:38 AM   #3
BRC 88MJ
Originally Posted by Muddinguy
I think i'd rather go with a corp bolt... you can change an axle shaft in minuites.. Dana 60 isn't full Floating is it ?
Depends on how they're built. Got a 60 from a late 70s Ford in my backyard that's FF. Dodge put a semi-float 60 in their late'60s/early '70s musclecars. Incidentally, I believe those SF 60s are 5x4.5" bolt pattern and very close to XJ/YJ/TJ width.
BRC 88MJ is offline   Reply With Quote
Old November 24th, 2005, 09:44 AM   #4
Big Daddy Rubicon
Mine is a semi-float and has a bolt pattern of 5x5 1/2 with a width of 60".
[/QUOTE]
Old November 24th, 2005, 10:00 AM   #5
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Options? Vendor? Cost? Lead Time?
Old November 24th, 2005, 11:58 AM   #6
Big Daddy Rubicon
Well they will add anything you want to fit any jeep made. I got mine from Daid at Northridge4X4.com, 1-360-340-0282. Cost is anywere from $4000.00 and up with what ever options your looking for. Time was about 3 weeks with shipping. If you call David tell him Daddy Rubicon sent you.
[/QUOTE]
Old November 24th, 2005, 12:53 PM   #7
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Just curious why you didn't go with a full float?
One thing I have never broke is a rear axle shaft... on the d35, the 8.8, or my 44....
You must get it too hard :tonka:
JcrOffroad
Zoom Zoom!
Old November 24th, 2005, 07:33 PM   #8
Big Daddy Rubicon
I wanted to run 15" wheels with disc brakes. Yes I was a little hard on the Beaver!!:tonka:
[/QUOTE]
Old November 27th, 2005, 07:13 PM   #9
bigblue2230
still goin
bigblue2230's Avatar
i run a locked 60 rear and have only sheared one axleshaft, and it slid right out, used a magnet to get the other half, and put the new one in. 15 minute job.
bigblue2230 is offline   Reply With Quote
Old November 27th, 2005, 07:36 PM   #10
You have a full float 60, though, right? With 30 spline dana 44 size shafts? Most factory full-floating Dana 60s are not using 35 spline 1.5" shafts..
Old November 27th, 2005, 09:09 PM   #11
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
John, who make the RockCrusher? Currie, Dynatrac, etc?
Also what did you do with the front axle bolt pattern? Well spacers that convert to 5 on 5.5?
Old November 28th, 2005, 12:39 PM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
14-bolts use 30 spline, 1.5" shafts, not 35; if that's the comparison you're trying to make.
And there's a big difference in strength between a semi-float 30-spline shaft and a full float 30-spline shaft, based on the full float vs semi float.
BDR - did you go 35 or 40 spline?
Old November 28th, 2005, 05:08 PM   #13
Big Daddy Rubicon
I have 35 spline axles in mine. Mike, Rockcrusher is made by hummmmm Rockcrusher out of Ohio.
[/QUOTE]
Old November 28th, 2005, 06:25 PM   #14
No, not talking about 14 bolts, talking about dana 60s. Many/most full floating Dana 60s like in a 90's Dodge 3/4 ton, or that there 70's F-250, have dana 44 size shafts. Sure they are full floating, but still 1.31" 30 spline shafts..
Dana 70s had the 1.5" 35 spline, as do semi floats. I'm sure at least some of the FF rears had the big shafts.
FF vs SF isn't a huge difference in strength when it comes to twisting a shaft from brute torque..
Old November 29th, 2005, 01:30 AM   #15
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Thanks BDR....I didn't know Rockcrusher was an actual brand/company like Dynatrac or Currie...just thought it was the name of the axle, like RockJock, or ProRock, etc.
Anyways what did you do about your front axle bolt pattern?
Old November 29th, 2005, 02:13 AM   #16
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
That isn't the majority of shaft failure though.
JcrOffroad
Zoom Zoom!
Old November 29th, 2005, 11:24 PM   #17
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
really mr smarty pants?
Mad Four Wheel Drive Introduces the Rock Crusher Dana 60R center section. These are manufactured in Australia and are guaranteed for a full year to be the strongest lightest steel differential center section on the market. This is a new product for the USA, but these have been in testing for some time in the land down under.
Old November 30th, 2005, 12:24 AM   #18
PavementPounder
PavementPounder's Avatar
D60 left vs. D70 right
Old November 30th, 2005, 02:24 PM   #19
bigblue2230
still goin
it's actually a dana 60 from a '73 chassis with the larger spline (18 i think, but not %100 sure)
Old November 30th, 2005, 03:05 PM   #20
Probably a 16 spline... If you ever break them, I'd bore out the spindles and upgrade to 35 spline 1.5" stuff..
I used to have a 1978 F-250 club cab long bed.. wish I still had that truck, was a lot of fun, but I didn't know what I was doing back then..
In general, full floating rear Dana 60s have Dana 44 axleshafts. 30 spline 1.31" shafts.
Dodge 3/4 & 1 tons from the 90s are the worst.. they have 32 spline 1.31" shafts in the front axle as well. Well, mid 70s F-350s I believe ran 30 spline inner/19 spline outers like Dana 44s..
Page generated in 0.40589 seconds with 83 queries
