purple ice question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2009, 04:13 PM   #1
jeep 8998
Default purple ice question
Has anyone used this or anything like it? I heard it works but not from anyone directlly. thanks eric
jeep 8998 is offline   Reply With Quote
Old July 1st, 2009, 11:23 PM   #2
93yj06unlimited
93yj06unlimited's Avatar
I have used RedLine Water Wetter in my Mustang, in both the 320 and the 466 I had. I have used it in my dirt bikes and snowmobiles also. It seems to perform as advertised. The Mustang with the bored and stroked 320cui. engine I had a hard time getting it to heat up past 160* after using the Redline WW, so when I put the 466cui in the Mustang I started with a hotter thermostat. The 466cui. is just slightly over 600hp and running 4.10 gears with a aluminum radiator and dual electric fans. With the WW you could run the engine for quite some time before I turned on the fans. It runs right around 185-190*. My 2007 Yamaha Attak snowmobile always ran hot on hard crusty snow and would turn on the amber warning light for temperature until I added the WW, now I can run it for about 15 minutes in 60* temps (stationary running on track stand) before the warning light comes on and it never comes on while riding anymore. My 4 stroke dirt bikes always puked some antifreeze while trail riding all day until after adding the WW, so in my opinion the Redline Water Wetter works and I have heard similar results for the Purple Ice. Hope this helps answer your question.
93yj06unlimited is offline   Reply With Quote
Old July 2nd, 2009, 12:20 PM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
you put water wetter in a snowmobile? ahahahahhahah!!!!AHHAHAHahAAA!!!!
Old July 2nd, 2009, 02:00 PM   #4
93yj06unlimited
Yes I did it is the 1000cc Genesis extreme 5 valve per cylinder,4cylinder, 4 stroke engine. The heat exchangers are mounted on the bottom of the running boards so if you're riding in crusty snow or on icy trails or lakes not enough snow gets up to the heat exchangers to cool off the engine, hence the Water Wetter. Smart Arse!!!!!
Old July 2nd, 2009, 02:47 PM   #5
Christmas Cookie
water wetter does not have any antifreeze properties in it...not a good idea to run in a machine that sits in sub zero temps...but hey what do i know...and your motor is just an old r1 design, nothing extreme about it
Old July 2nd, 2009, 04:20 PM   #6
warner-racing357
WARNER-RACING
warner-racing357's Avatar
I use liquid ice in my race quads and it lowers the temp about 15 deg.
warner-racing357 is offline   Reply With Quote
Old July 2nd, 2009, 06:10 PM   #7
Christmas Cookie
do you mean engine ice? which I think you do, then yea thats good stuff, plus it HAS antifreeze properties so you can use it in the winter and its safe. I used to run that stuff in my track bikes
Old July 2nd, 2009, 06:20 PM   #8
joe_jeep
welfare wheeler
joe_jeep's Avatar
water wetter is a product you add to your existing antifreze. you dont use it in place of all your anitfreeze. ive heard good things about it, but never used it. ive sold tons of it over the years when i was in the parts biz.
i have no idea about the purple ice product? im asuming its similar but made by royal purple?
Old July 2nd, 2009, 06:33 PM   #9
Hunter9
Not Right!
Hunter9's Avatar
Of coarse it doesn't that is why it is called an additive.......
I do not think OP replaced his AF with it.
Hunter9 is offline   Reply With Quote
Old July 2nd, 2009, 06:41 PM   #10
jeepinRRT
jeepinRRT's Avatar
X2 on the Engine Ice when I raced. I used it in my 250 and 450CRF's with similar results. If your looking for cooler temps, spend the $$$ on the good stuff.
jeepinRRT is offline   Reply With Quote
Old July 2nd, 2009, 09:01 PM   #11
ajmorell
ajmorell's Avatar
Used the Purple Ice in my ZJ, seemed to drop the operating temp 10 degrees or so.
Old July 2nd, 2009, 10:00 PM   #12
93yj06unlimited
Well if you know so much then you know that Yamaha runs the coolant about 90% antifreeze and about 10% water. Great for stopping the freezing but does'nt do much to help heat transfer. So I removed some antifreeze and refilled with Distilled water and the Redline Water wetter. It is still protected to -45*F. Nothing Extreme about it huh try 122mph speedo 118mph GPS in snow going across the airstrip in Grand Marais and it was still pulling hard I honestly just ran out of nerve
Old July 2nd, 2009, 11:00 PM   #13
joe_jeep
welfare wheeler
joe_jeep's Avatar
i have rode the apex ltx gt 40th anniversary edition a hand full of times. its wicked fast. its also heavy! dont get it stuck, you will be there a while digging it out. the 4 stroke takes some getting used to, amazing torque. ive rode faster, but it was far from stock.
the fastest stock sled ive been on. it will beat the 06 900 fusion, the 03 f7, and the 03 xcsp800. we have raced all of them many times.
Old July 3rd, 2009, 06:35 AM   #14
So has anyone tried all of the ones mentioned and found one to be better than another?
Old July 3rd, 2009, 07:50 AM   #15
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
I used the purple ice "additive" in my Jeep hoping I could get even a 5° reduction, but I didn't notice a damn thing.
ppkaprince98 is online now   Reply With Quote
Old July 3rd, 2009, 08:04 AM   #16
Paul04TJ
Small, but talented
Paul04TJ's Avatar
We ran water wetter in the Datsun and saw an average 8-10 degree drop.
2.95L w/13.25:1 compression.
Paul04TJ is offline   Reply With Quote
Old July 3rd, 2009, 03:38 PM   #17
jeep 8998
thanks for everyones input I will check out that engine ice i've never heard of that thanks again eric
Old July 6th, 2009, 10:54 AM   #18
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I am a water wetter user. It works if you just need a small drop in temp.. I also use it my my sled (06 rev). As said, it helps coolant absorbe and release heat.
RIP FULLSIZE4LIFE
Old July 6th, 2009, 11:49 AM   #19
mzy4v1
40's baby!
mzy4v1's Avatar
I recently added the Water Wetter in my 04 Rubicon, definitely noticed about a 10-15F drop in running temperature.
mzy4v1 is offline   Reply With Quote
Old July 7th, 2009, 07:46 PM   #20
Christmas Cookie
When I ran water wetter in y race egines it was water wetter + water and that was it...it was not used as an adivtive to antifreeze, as you are not allowed to run antifreeze on road courses, however you could use engine ice...I liked the ice better because I didn't have to worry about draining it out in the winter
Page generated in 0.39749 seconds with 83 queries
