4l60e ? help please - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2009, 05:56 PM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default 4l60e ? help please
95 z71 350/4l60e
ok my truck was fine, i go through the atm and i go to take off and it was lugging real bad so i put it in first and it down shifted to 1st and was fine. so i stop and check the fluid and it was at the full cold mark and was fully warm so i added 1 qt to fill it up. it was fine again then i stop at a stop light and now all i have is 3rd and 2nd but to get 2nd i have to manually down shift, i cant get 1st or 4th or tcc lock up.
i cant think of any thing that would cause this, any ideas?
beaterk5 is offline   Reply With Quote
Old June 29th, 2009, 07:51 PM   #2
storey469
it could be in the trans. i had an issue with my 96 chevy half ton. it has the 4L60E in it. i lost 3rd and 2nd gear. i ended up replacing the clutch plates, gears, and putting a shift kit in.
storey469 is offline   Reply With Quote
Old June 30th, 2009, 07:11 AM   #3
Tom
Because racecar
Tom's Avatar
You need to have it scanned for codes first. It could be a shift solenoid or 3-2 down shift solenoid.
Old June 30th, 2009, 07:57 AM   #4
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
4L60E's suck. Ask anyone who has owned one.
Old June 30th, 2009, 03:51 PM   #5
beaterk5
beaterk5's Avatar
ok update im starting to think there connected i also had my dash wig out twice and it hasnt again the spedo and tach stoped working but the rest stayed working? and the check gauges light came on
Old July 6th, 2009, 08:32 PM   #6
tyzstuff
[ ]lllll[ ]
tyzstuff's Avatar
Is the shift indicator light going out when you have the tranny problems?If so it isthe ignition switch.Mine did that to me a week after I bought it in 96.If not I would go with the scan and the shift silionoids.I also had to do that after having a tranny flush.The force of the flush took two of mine out.
tyzstuff is offline   Reply With Quote
Old July 8th, 2009, 01:30 PM   #7
beaterk5
beaterk5's Avatar
yes the light goes out too, but it has only done it once or twice since i fixed some grounds, and i did the solinoid test with the scenner and there fine
thanks im going to check into the ignition switch
Old July 10th, 2009, 06:22 PM   #8
beaterk5
beaterk5's Avatar
ok, it started acting up again so i took out the cluster and the problem goes away when i take it out but comes back as soon as i put it back in. can any one explain this?
Page generated in 0.39165 seconds with 47 queries
