camaro rs engine swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2009, 08:46 PM   #1
arcticatdude
Default camaro rs engine swap
I was thinking about buying a 1992 camaro rs and putting a 350 in it, but I don't know if it can be done or what engine the camaro has.thanks.
arcticatdude is offline   Reply With Quote
Old June 26th, 2009, 08:50 PM   #2
Bishop
Bishop's Avatar
everything should drop in just like it was meant to be there. just have to wire it up. and the usual swap changes like exhaust and fuel lines and stuff
Old June 27th, 2009, 11:01 AM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if you have an RS you already have the 305. putting a 350 in is a no brainer. simple as removing current engine and installing new one
Old June 27th, 2009, 03:56 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
+2
I've done a few 2.8 to small block swaps in these and all you need to change is the motor mount pads on the frame to a small block pad. If it does have a 305 in it, swap it out. No problems.
Old June 28th, 2009, 09:52 PM   #5
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
if u have done 2.8 to small blocks then u obviously know that the transmission must be switched???
84ChevyMuscle is offline   Reply With Quote
Old June 29th, 2009, 07:06 AM   #6
jbsjunk
Little Member
jbsjunk's Avatar
And you'll need to get the bracketry for the torque arm which bolts to the end of the trans. But since this is more than likely a 5.0 car, the trans isn't a issue. Of course, if it's a 2.8 the trans will need to go.
Page generated in 0.39460 seconds with 41 queries
