louver shop? SE michigan. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2009, 10:46 AM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default louver shop? SE michigan.
lookin for someone to add some louvers to my jeeps hood. anyone know a shop that does it?
nate4d is offline   Reply With Quote
Old June 25th, 2009, 10:59 AM   #2
capone
capone's Avatar
John Schumont, in Southfield, 734-377-4522
Calls his business "Hot Rod Louvers
Or I have a brand new set of Gen right hood louvers I will sell you for a $40.00
http://www.genright.com/ProductInfo....ductid=LVR1006
capone is offline   Reply With Quote
Old June 26th, 2009, 09:20 PM   #3
Blackjackbender
ur an idiot. stop wasting ur money on dumb upgrades. ever think if your over heating there is something wrong with your cooling system.
Old June 26th, 2009, 10:40 PM   #4
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Nuzzy is offline   Reply With Quote
Old June 26th, 2009, 10:41 PM   #5
curt1656
Praise the lowered
curt1656's Avatar
Yeah what he said. Nathan.
Old June 26th, 2009, 11:34 PM   #6
firehawk
Live Action!
firehawk's Avatar
Louvers are Gay!
Old June 26th, 2009, 11:38 PM   #7
1badzuk
1badzuk's Avatar
grinder + hammer you supply beer ill help
1badzuk is offline   Reply With Quote
Old July 31st, 2009, 04:30 PM   #8
four_by_ken
Need a strap?
four_by_ken's Avatar
I do agree that if you are doing this for a cooling reason on a Jeep. You should look into a better radiator before adding louvers.
four_by_ken is offline   Reply With Quote
Old July 31st, 2009, 07:03 PM   #9
95geo
newbie
95geo's Avatar
louvers increase cooling ability by 43%
Old August 3rd, 2009, 09:07 AM   #10
PavementPounder
PavementPounder's Avatar
More surface area to give off heat won't matter if you can't evac the heat it gives off. Like 95geo said, getting the hot air out of the engine compartment is extremely effective. If the air can't get out, not only are you keeping heat in, but that air fights your fans and slows down the air moving though the radiator.
Old August 3rd, 2009, 09:09 AM   #11
nate4d
Gnarley Davidson
nate4d's Avatar
brand new radiator, thanx tard
Old August 3rd, 2009, 10:06 AM   #12
95geo
newbie
95geo's Avatar
I was being sarcastic with the % but PP's right in that if you never allow the heat in the engine bay to escape then you wont have enough delta to performt the heat exchange and it'll slowly increase temps until something gives, most of the time it doesnt cool itself. You can do some easy checks to see if you need to get more air through your engine bay or not.
Drive in a set patern in a very repeatable style and then remove your hood and do the same, then just crack the front of the hood open and do it again and see what changes you see. you are going to need either a laser temp gun or a full sweep aftermarket gauge to see the changes.
If you arent against it, removing the inner fender wells is probably the easiest way to vent the engine bay.
Old August 3rd, 2009, 03:25 PM   #13
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
So stock Jeeps with 4.0L overheat then? Tard, did you check your fan clutch?
Old August 3rd, 2009, 03:39 PM   #14
nate4d
Gnarley Davidson
nate4d's Avatar
never said it overheated, just would like it to run a littlebit cooler. at the dunes and on the tight and twistys it gets a little above 210 so i figure along with the looks, it wouldnt be a bad idea to cool it down as well.
Old August 3rd, 2009, 03:57 PM   #15
muddyjeep9
muddyjeep9's Avatar
Still running warm after we did the swap? And new thermostat
muddyjeep9 is offline   Reply With Quote
Old August 3rd, 2009, 04:16 PM   #16
95geo
newbie
95geo's Avatar
210 is not too hot. 210 is well within the design parameters of a pressurized cooling system, 230 would be considered hot and you're about to do damage around 240
If you are doing it for looks then spend the money on something else.
Old August 3rd, 2009, 04:24 PM   #17
HVYRTFT
Reed my teef
HVYRTFT's Avatar
why are they OE on 5.9ZJ's? Must be because they don't do anything.
Page generated in 0.34831 seconds with 74 queries
